Page 3 of 3 1 2 3
Re: Turbo Question [Re: topfueldart] #1571537
02/02/14 05:59 PM
02/02/14 05:59 PM
MR_P_BODY Offline OP
I agree with a lot that's been said already. Compressor A/R is a useless measurement for our purposes, but turbine A/R is very important. Trim is also a term rarely used, just look at the compressor wheel measurement.
On 418 inches, the twin 1.05 turbines might be a bit laggy, but they will work. Don't be afraid to look at build threads of Chevy and Ford combos online, similarly sized engines will offer good info about the spool characteristics of a pair of those turbos.
Looks like I'm gonna try a 60 and a .96
A as in 1? or still twins? I think twin 60/61/67's, would work very well with .96 turbines.
Twins.... as in 2... so you believe I'm headed in
the right direction
Re: Turbo Question [Re: topfueldart] #1571538
02/03/14 03:12 PM
02/03/14 03:12 PM
Next Question... is there really any difference between
the inlets of the turbine... one rectangular hole or
2 smaller ones... does it help or hurt either way
Re: Turbo Question [Re: MR_P_BODY] #1571539
02/03/14 03:34 PM
02/03/14 03:34 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Divided housings are designed for split manifold diesel aplications. They flow less than an open version of the same a/r, and are usaully cast of a lower nickel content iron. I would pass on these, but I personally have used them. They did end up cracking around the flange inlets, But I was "heat stacking" them, so other's results may vary...
Re: Turbo Question [Re: TRENDZ] #1571540
02/03/14 04:03 PM
02/03/14 04:03 PM
Thanks... good to know... so I'll be looking for the
larger single opening style
Re: Turbo Question [Re: topfueldart] #1571541
02/07/14 03:47 AM
02/07/14 03:47 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Switch to E85 non intercooled with the twin GT45 y2004k turbos
My 383 needs twins witch I have but got lazy and didn't feel like relocating the alternator.
Mine car is on Methanol now, lag was never a problem on E85.
Re: Turbo Question [Re: RockChip] #1571542
02/07/14 01:03 PM
02/07/14 01:03 PM
Why would you say no inter coolers... isnt the name
of the game to get a cool/cold inlet charge... you
dont think a pair of GT45s would be a bit muchEDIT
I dont know anything or heard anything on those y2004k
Re: Turbo Question [Re: MR_P_BODY] #1571543
02/07/14 02:38 PM
02/07/14 02:38 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think what he was saying is that with E85 or methanol, an intercooler isn't as much of a gotta have at the boost levels that most mere mortals can afford.
With a blow-thru setup the alcohol vaporizing cools down the charge. I'm sure you have seen NA alcohol cars at the track with frost on the intake even on the hottest days. Highschool physics was a lifetime ago but I think the principal was called "latent heat of evaporisation" or some such.
If you are running gas as your main go to fuel the intercoolers are pretty much gotta have if you are planning on more than single digit boost levels.
Kevin
Re: Turbo Question [Re: Twostick] #1571544
02/07/14 02:46 PM
02/07/14 02:46 PM
Kevin
Being this will be my Drag Week car I cant plan on
E-85(no such animal in parts of the country) so my
plan is regular pump fuel... would like to run 87
but race on 93 octane... that will require some testing
to see what pressure I can get away with on the 93
so the inter cooler are a must(in my opinion).. which
I have a couple... its not like I have to spend money
on them
Re: Turbo Question [Re: MR_P_BODY] #1571545
02/07/14 03:25 PM
02/07/14 03:25 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Not that I really know anything about this stuff...but you could even consider running the intercooler AND an Alcohol Injection setup while racing....
Re: Turbo Question [Re: Quicksilver440] #1571546
02/07/14 03:33 PM
02/07/14 03:33 PM
I may end up using a meth/water injection set up but
if I can get away with out it I would prefer not using it...
I still like the KISS ways of doing it... once I get
this build up and running I'll test to see what I
can get away with
Re: Turbo Question [Re: MR_P_BODY] #1571547
02/07/14 03:58 PM
02/07/14 03:58 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can get away with alot more if you run a cam with longer duration than most "turbo cams". You get a proportional egr effect with rising boost/ backpressure levels. Trust me , this works. you will be able to run any pump swill along the way.
Re: Turbo Question [Re: TRENDZ] #1571548
02/07/14 04:02 PM
02/07/14 04:02 PM
I assume due to closing the valve a bit later
Re: Turbo Question [Re: MR_P_BODY] #1571549
02/12/14 12:55 AM
02/12/14 12:55 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Twostick, couldn't have said it any better myself.
If your heart is set on gas then yes intercool it.....
Some of the eBay water to air actually work Verry good.
Water/meth works well also, as long as the atomization is good.
Also, I have had better luck with running straight distilled water.
Page 3 of 3 1 2 3
