I'm looking to add a pair of turbos to my 416..I
was doing some sizing but ran into a snag... I dont
want much in the line of power... this is more for the
go fast look... I really dont want more than 300 hp
over the N/A power or I might end up ripping the block
apart... what I was looking at was a pair of GT45...
the specs show
T4 flange
4" V-band outlet
comp wheel trim : 50
comp A/R 0.066
turbine wheel trim 77
turbine A/R 1.05
what do you think about this... I wont be going
more than 7200 rpm and was thinking to keep the boost
in the 6 psi range... would this one be a bit slow
to come in... remember this would be twins.. good
flowing heads in a 2900# car... I will be running
air/air inner coolers(2 of them)
thanks guys.... I figured I'd ask instead of doing
all the flow calculation on this engine(but maybe I
will end up doing it)
