Late 70's Delay Wiper question.... #1571429
01/31/14 03:02 AM
01/31/14 03:02 AM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I need a wiring diagram for an (I think) late 70's dodge with delay wipers. A number of years ago I pulled the wiring out of a dodge van that had delay wipers. Got everything, the switch, wiper motor, delay timing box, etc. I don't know the year of it but it looked maybe late 70's or early 80's. The delay wiper switch was a slider switch on the dash and not on the signal lever. I need a wiring diagram for it and I want to see if I can get it working on the bench before I go to swap it all into mine. Any help?
Re: Late 70's Delay Wiper question.... [Re: DaytonaTurbo] #1571430
01/31/14 03:15 AM
01/31/14 03:15 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
My Parts catalog says 81 is the first year for intermittent wipers
I'll see if I can take a pic of the wiring diagram from the manual that can be read easily
Re: Late 70's Delay Wiper question.... [Re: BulletBob] #1571431
02/11/14 03:14 PM
02/11/14 03:14 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
It was offered in cars across the board in '78. Trucks I don't know for sure.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Late 70's Delay Wiper question.... [Re: Magnumguy] #1571432
02/12/14 03:42 PM
02/12/14 03:42 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Optional item in 79 Vans for sure. I just added it to mine a couple weeks ago (still need to buy the correct motor though).
On the 79 it was a separate harness that plugged into the existing one via a 3 way molex, add the correct switch, add the 5th wire to the wiper motor and swap the motor.
On my 85 parts van it was a more 'built-in' install from the factory and that is where I got my parts from. So I trimmed out all the wires I needed and using some molex plugs from radiohack to make it as close to a 79 type install for future troubleshooting needs if it ever arises (hopefully it wont)
