When was the Heater Valve used on cars? #1571235
01/30/14 03:35 PM
01/30/14 03:35 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I am trying to restore this heaterbox and I found the core has two holes in it. I ordered that...I traced all the vacuum lines on the heaterbox but there is one that was just hanging there with a plastic nipple in the hose....its close to the fan motor. Luckily all the diaphragm pods work and the fan motor is working..
When was the heater valve used on cars? I am looking in the manual and there really isn't a reference to it. I see two bolts on the Passenger side fenderwell and just assuming that the heater valve is placed there.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: When was the Heater Valve used on cars? [Re: Pyper70] #1571236
01/30/14 04:01 PM
01/30/14 04:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If I remember right (CRS) when you turn the A/C on the valve cuts off the water flow.
Re: When was the Heater Valve used on cars? [Re: 71birdJ68] #1571237
01/30/14 07:43 PM
01/30/14 07:43 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
okay so its nothing critical then...we can always add it in later if need be...the A/C isn't hooked up anyways
Re: When was the Heater Valve used on cars? [Re: Pyper70] #1571238
01/31/14 01:00 PM
01/31/14 01:00 PM
pa.
dan9 Offline
dan9  Offline
pa.
I also think that vacuum hose with the plastic nipple goes to the vacuum "tree" that provides vacuum to the power brakes.
Re: When was the Heater Valve used on cars? [Re: dan9] #1571239
01/31/14 02:19 PM
01/31/14 02:19 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
on my 70 cuda theres a cable operated heatervalve on the passengerside inner fender,i need it to turn on and off the heat.also theres a vacuum hose that enters the engine bay from the interior,it goes to a nipple at the rear of the oem holley and also tees to the dual snorkel air cleaner pods.
