any trick to removing Ball Joints from UCA's? #1570732
01/29/14 07:35 PM
01/29/14 07:35 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I used to have the tool but I let someone borrow it and well...thats the end of that one...Dont feel like spending $55 for a new socket...I am also worried about stripping the threads on the UCA...is there any trick to removing it through years of broken knuckles? Should I be soaking it with Liquid Wrench for a few days before I attempt the task? Should I heat it up with some Mapp Gas to break it loose? Should I whack it with a hammer? Should I give it some Red Bull and cross my fingers that it willfully surrenders on its own?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570733
01/29/14 07:44 PM
01/29/14 07:44 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Just spend the money on a new proper socket for it ,and it makes for an easy job of it. (Easy as it can be that is..)
And then just use a Good impact gun or a really long breaker bar, should be all you need. Then reverse again to install the new ball joint.
Re: any trick to removing Ball Joints from UCA's? [Re: OzHemi] #1570734
01/29/14 07:49 PM
01/29/14 07:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If the UCA's are off the car, just take them into a local shop and ask them to yank them off. Probably do it for a coffee!
Re: any trick to removing Ball Joints from UCA's? [Re: Stanton] #1570735
01/29/14 08:15 PM
01/29/14 08:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I wouldn't think...I could be wrong...but would not think many local shops in Greece would have Mopar ball joint sockets?
They would probably just try to press the ball joints out instead.
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570736
01/29/14 08:17 PM
01/29/14 08:17 PM
Andrewh Online content
Andrewh  Online Content
not sure what shipping would be, but napa and a few other places sell them cheaper than 55 bucks.
I saw that right after I paid like 80 bucks for my snap on one, you could then buy them for 12 bucks I think.
Re: any trick to removing Ball Joints from UCA's? [Re: Andrewh] #1570737
01/29/14 08:47 PM
01/29/14 08:47 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
If you can find a Mopar ball joint socket anywhere,from anyone, for $12.00, buy every one that you can get, sell them, and make a tremendous profit.
When were they ever 12 bucks, on this planet?
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: any trick to removing Ball Joints from UCA's? [Re: hemi71x] #1570738
01/29/14 08:50 PM
01/29/14 08:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pipe wrench works when you have nothing else.
Re: any trick to removing Ball Joints from UCA's? [Re: hemi71x] #1570739
01/29/14 09:11 PM
01/29/14 09:11 PM
trust me they were. must have been 5 or 6 years ago now. maybe a little more.
I just remember someone even on this board talking about them, and me kicking my self for spending so much on one not that long before that.
http://www.summitracing.com/parts/sxt-10213
ok 16 bucks.
Re: any trick to removing Ball Joints from UCA's? [Re: Andrewh] #1570740
01/29/14 09:28 PM
01/29/14 09:28 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
14.30 pro shop price + ship 4.95 still great price....just ordered 2...pat NOTE...I believe there are three sizes a b c bodies also difference in years order correct one....
Re: any trick to removing Ball Joints from UCA's? [Re: pattyboy 572] #1570741
01/29/14 09:34 PM
01/29/14 09:34 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
prices sure have come down...I might as well buy one of those then....I mean...I have to remove it...but I also have to crank it back in right....I sure hope those threads don't strip out....it happened to my 70 Charger and it was FUN looking for decent UCA's
Thanks fellas
Re: any trick to removing Ball Joints from UCA's? [Re: Andrewh] #1570742
01/29/14 09:37 PM
01/29/14 09:37 PM
hemi71x Offline
hemi71x  Offline
ok 16 bucks.
Wow, ok, but is that Summit one, for the small ball joint A body cars, or large ball joint A, B, E, body cars.
Re: any trick to removing Ball Joints from UCA's? [Re: hemi71x] #1570743
01/29/14 09:41 PM
01/29/14 09:41 PM
new york usa
P
P
new york usa
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570744
01/29/14 09:41 PM
01/29/14 09:41 PM
several days worth of apps of kroil or pb blaster never hurts. As Stump said if you can get a pipe wrench on there & keep it square it'll work most of the time. DEFINITELY take em off before you take the UCA itself out. If the socket is cheap & you ain't in no rush to order it then as you know having the proper tool is always the better way
Re: any trick to removing Ball Joints from UCA's? [Re: RapidRobert] #1570745
01/30/14 12:20 PM
01/30/14 12:20 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Buy the damn tool.
Sell it on ebay later.
Re: any trick to removing Ball Joints from UCA's? [Re: Commando1] #1570746
01/30/14 02:55 PM
01/30/14 02:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
C'mon, what man buys a tool and then sells it ?!?!?!
Re: any trick to removing Ball Joints from UCA's? [Re: Commando1] #1570747
01/30/14 02:57 PM
01/30/14 02:57 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I couldn't get them out on my 84 truck even with the socket. So I do have a mig welder. I welded a short piece of scrap 2" tube to one and the heat of welding loosened it up enough to spin out with a pipe wrench took the one I had out flipped it over and welded it to the outer side and it came out easy to. Threads were fine and quite clean. Have some water handy as the grease in the old ball joint tends to catch on fire!
Re: any trick to removing Ball Joints from UCA's? [Re: Commando1] #1570748
01/30/14 03:27 PM
01/30/14 03:27 PM
pa.
dan9 Offline
dan9  Offline
pa.
Or do what someone did when i got mine. They bought it, used it and returned it.
Re: any trick to removing Ball Joints from UCA's? [Re: dan9] #1570749
01/30/14 06:42 PM
01/30/14 06:42 PM
P
Paul_Fancsali Offline
P
No matter how careful you are you will probably strip the threads on roughly 70% of the ones I have seen done. Get a mig welder and just tack them in solves the problem
Re: any trick to removing Ball Joints from UCA's? [Re: Paul_Fancsali] #1570750
01/30/14 07:41 PM
01/30/14 07:41 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Went ahead and ordered the socket...I'll use it....probably keep it as you never know when you need one....I will clean the UCA's tomorrow and put in some liquid wrench for a few days until the socket arrives...Hopefully its not part of the 70%
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570751
01/30/14 07:44 PM
01/30/14 07:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Leave the control arms on the car to remove the ball joints or you could end up twisting them out of shape.
