Towing my 4X4 with a tow dolly #1570551
01/29/14 04:12 AM
01/29/14 04:12 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
My 78 4x4 truck with 727 trans.
I know that some auto trans can be damaged towing with the rear wheels on the ground unless you add a pump to lube the tranny. Is this necessary with my truck or is this tranny OK without an modification?
Re: Towing my 4X4 with a tow dolly [Re: 696pack] #1570552
01/29/14 04:40 AM
01/29/14 04:40 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
If the trany's good I wouldn't take the chance & tow it backwards, & put the magnet base lights on the bumper. Just me.
The old push button trans had a pump in the rear & was told they could be towed, though I never have.
Edit: I just saw your other post on front wheel bearing so I see where you are coming from now.
Re: Towing my 4X4 with a tow dolly [Re: 696pack] #1570553
01/29/14 04:42 AM
01/29/14 04:42 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
DEPENDS on the distance you want to tow it ...
Re: Towing my 4X4 with a tow dolly [Re: dOrk !] #1570554
01/29/14 04:47 AM
01/29/14 04:47 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
put the front wheels on the dolly. put the T case in neutral and go for it..
I am truckless..
Re: Towing my 4X4 with a tow dolly [Re: 340SHORTY] #1570555
01/29/14 04:50 AM
01/29/14 04:50 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
transfer case,...Doh!!
Re: Towing my 4X4 with a tow dolly [Re: 340SHORTY] #1570556
01/29/14 02:16 PM
01/29/14 02:16 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Did you mean the REAR wheels?
And for the one that asked, I would be towing about 500 miles round trip.
Re: Towing my 4X4 with a tow dolly [Re: 696pack] #1570557
01/29/14 02:45 PM
01/29/14 02:45 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
If your towing 500 miles, just be safe and pull the rear driveshaft.
Then no chance of it bouncing into gear, or T case bouncing out of neutral.
Its a 4x4 so getting to the rear shaft shouldn't be too hard.
And its full time 4x4 so you can still drive it on and off the dolly, just put the T case in 4 High Loc and the front axle will drive you around.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Towing my 4X4 with a tow dolly [Re: 696pack] #1570558
01/29/14 05:47 PM
01/29/14 05:47 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NO, I said FRONT wheels. You want the weight on the dolly. Most dollys dont have a long enough toung to compensate for the bed overhang for turning clearance.
I am truckless..
Re: Towing my 4X4 with a tow dolly [Re: 340SHORTY] #1570559
01/29/14 11:01 PM
01/29/14 11:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
....and you're better off with heaviest end on the dolly for safer tow.
