Re: Towing my 4X4 with a tow dolly
[Re: 696pack]
#1570552
01/29/14 04:40 AM
01/29/14 04:40 AM
Posts: 1,805 ky hills
thehemikid
ky hills
If the trany's good I wouldn't take the chance & tow it backwards, & put the magnet base lights on the bumper. Just me. The old push button trans had a pump in the rear & was told they could be towed, though I never have. Edit: I just saw your other post on front wheel bearing so I see where you are coming from now.
[Re: 340SHORTY]
#1570556
01/29/14 02:16 PM
01/29/14 02:16 PM
Posts: 511 AZ.
696pack
AZ.
put the front wheels on the dolly. put the T case in neutral and go for it..
Did you mean the REAR wheels?
And for the one that asked, I would be towing about 500 miles round trip.
[Re: 696pack]
#1570557
01/29/14 02:45 PM
01/29/14 02:45 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
If your towing 500 miles, just be safe and pull the rear driveshaft.
Then no chance of it bouncing into gear, or T case bouncing out of neutral.
Its a 4x4 so getting to the rear shaft shouldn't be too hard.
And its full time 4x4 so you can still drive it on and off the dolly, just put the T case in 4 High Loc and the front axle will drive you around.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
