78 4X4 front wheel bearings #1570535
01/29/14 04:07 AM
01/29/14 04:07 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
What's up with this design? Although I have not looked at it myself my mechanic says it is some ridiculous set up that is going to be very expensive to replace them? Can someone give me some insight please?
Re: 78 4X4 front wheel bearings [Re: 696pack] #1570536
01/29/14 04:49 AM
01/29/14 04:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yep poor design.. not really that expensive,
L & S AUTOMOTIVE PRODUCTS Part # A22
Front Outer Bearing Set; 1/2 TON and 4 WHEEL/ALL WHEEL DRIVE,SPICER 44F-BJ
Front Inner Bearing Set; 3/4 TON and 4 WHEEL/ALL WHEEL DRIVE,SPICER 44F-BJ
Front Inner Bearing Set; 1/2 TON and 4 WHEEL/ALL WHEEL DRIVE,SPICER 44F-BJ
Front Outer Bearing Set; 3/4 TON and 4 WHEEL/ALL WHEEL DRIVE,SPICER 44F-BJ
Choose:
$29.79
I am truckless..
Re: 78 4X4 front wheel bearings [Re: 340SHORTY] #1570537
01/29/14 09:16 AM
01/29/14 09:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Until you have done one you wont believe how some one could even design such a stupid setup.Ive done quite a few.Its a bit of time just getting the inner bolts out.Need IIRC a 3/8 thin deep well 12 point socket for them.Then hope the heads dont round off.Then when the hub comes off get the bearings off it.Mine were all well worn Ohio rusters.Rocky
Chrysler Firepower
Re: 78 4X4 front wheel bearings [Re: 340SHORTY] #1570538
01/29/14 10:30 AM
01/29/14 10:30 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Except if you need new knuckles and rotor hubs. Then you have the 3 piece inner seal for greasing and the outer seal in the retainer. Once the bore in the knuckle is worn you will never be able to get the bearings tight which equals slop in the wheel itself. There is a reason they only ran it for a few years. Junk. Whats real funny is the idiots that think its a great perfect set up.
Re: 78 4X4 front wheel bearings [Re: 340SHORTY] #1570539
01/29/14 12:46 PM
01/29/14 12:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Most mechanics say anything is expensive just to make some money.
Re: 78 4X4 front wheel bearings [Re: NITROUSN] #1570540
01/29/14 02:15 PM
01/29/14 02:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Nitrousn I forgot about the knuckles.One I had I had to hunt 20 yards to find used knuckles and that was in the 80s.Once they really start to wear the wheel gets tons of sloop and wants to lean.That and the grinding.I bought one RamCharger real cheap because of the knuckle hub wear.Took me about a month to fix it because I had to find parts cheap.You used to be able to buy a complete hub.They were pricey even back then.Rocky
Chrysler Firepower
Re: 78 4X4 front wheel bearings [Re: NITROUSN] #1570541
01/29/14 02:28 PM
01/29/14 02:28 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
So, is it possible and cost effective to replace what is there with a later version set up? I have to weigh the fact that if I fix what I have I should never have to worry about it again at my age so if switching (if possible) will serve no purpose in the long run. I am just looking for the most cot effective way to fix this.
Re: 78 4X4 front wheel bearings [Re: 696pack] #1570542
01/29/14 02:53 PM
01/29/14 02:53 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I'm sure the knuckles , hubs, axles, and rotors from a 1980 1/2 ton will swap right in. Then there's the question of whether you want to do the conversion to the transfer case..
Re: 78 4X4 front wheel bearings [Re: 696pack] #1570543
01/29/14 02:56 PM
01/29/14 02:56 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Its not that bad of a setup, sure its complicated, but they did make it easy to grease the bearings, just most got neglected. It wasn't designed to be disassembled for maintenance.
There are trucks on the road today with factory bearings in them, so they weren't that bad if used as designed.
Now when you start adding big ass tires, and offset wheels, then your going to have issues.
If you dont take the front wheels off and grease the hubs your going to have issues, but if you grease the hubs when you rotate the tires or at least twice a year, they will normally live a long and happy life.
I put a 78 D44HD under my 93 Ramcharger, partly because I got a smoking deal on a military surplus rebuilt unit, and mostly to be rid of the goofy self locking front end that I dislike.
I wont run over about a 32" tire on the front, and my wheels are a typical 8" with near center offset. I'm sure I will get plenty of use out of the setup once its out on the road and not in the garage.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 78 4X4 front wheel bearings [Re: superwrench] #1570544
01/29/14 02:58 PM
01/29/14 02:58 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
You can also run the Chevy truck stuff from the knuckles out. I have heard of several guys doing that.
Re: 78 4X4 front wheel bearings [Re: hp383] #1570545
01/29/14 11:39 PM
01/29/14 11:39 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
The only thing good about them was they were nice to grease, I feel that if they could have spaced those bearings farther apart there would have been less problems with them
Re: 78 4X4 front wheel bearings [Re: superwrench] #1570546
01/30/14 12:02 AM
01/30/14 12:02 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
No need just leave the hubs locked
Re: 78 4X4 front wheel bearings [Re: 76dodgeboy] #1570547
01/30/14 12:15 AM
01/30/14 12:15 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
I have drilled a hole in the wheels to make greasing them a lot easier...
Re: 78 4X4 front wheel bearings [Re: Mopar2DBone] #1570548
01/30/14 01:01 AM
01/30/14 01:01 AM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
No big deal once you've done one...the first try is the hardest, after that, it's just procedure...
My Dad's '76 still runs the factory setup and has only had those bearings replaced once, although I do hit 'em with some grease every oil change.
FYI NAPA sells a complete unit...rotor/hub/bearings, bolt on replacement for these trucks. I haven't ever used this setup, but came across it on the NAPA online website after I did a set of bearings on a friends '77 W100. That would have been much easier (his needed the rotors replaced as well).
Good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 78 4X4 front wheel bearings [Re: AdventurerSport] #1570549
01/30/14 10:02 PM
01/30/14 10:02 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Do you have the part numbers for this set up?
Re: 78 4X4 front wheel bearings [Re: 696pack] #1570550
01/31/14 11:35 PM
01/31/14 11:35 PM
Morningside
Morningside
No, I do not. I bought a set that way about 3 years ago, I would suggest that you call a local NAPA and see if that setup is still available. It was sweet, bolt on, no mess/no fuss!
Good luck!
JS
