Re: Best way to lower a 54 Pilothouse PU?
[Re: poorboy]
#1570040
01/29/14 12:48 AM
01/29/14 12:48 AM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
Does it still have the beam front axle? You can modify the axle and move it above the springs instead of being below the springs. If you do this, watch the oil pan clearance. Short of this, you can probably remove every other spring from each front spring pack. The next option is a Mustang II suspension, or other front frame clip (like a Dakota).
Have the brakes been upgraded? Also, take care of that windshield, they are hard to find and expensive, only fit 54 and early 55. Gene
It has the stock axle up front. I'm looking at having "Sids" re-shape the front for a 3" drop ($350) and then removing leaves to lower more if needed. It has drum brakes though they have been rebuilt. Discs are on my mind for sometime. I haven't bought it yet. I wanted to see what I was getting into before I jumped in.
[Re: Dabee]
#1570042
01/29/14 10:39 AM
01/29/14 10:39 AM
wedgeheaded
Friendly, WV
Nice truck. Put a Dakota front clip on it and it will look like this. [/quot
I so dig that truck. It's part of the reason I'm looking at this 54. I kinda want to keep it old school though. (at least for now) A frame swap is a big, time consuming job. I just don't have the time right now. I'd love to see more of your truck if you have pics. I'm at addes426@gmail.com
[Re: savoy64]
#1570044
01/30/14 01:46 AM
01/30/14 01:46 AM
Posts: 3,437 Dandridge TN
Dabee
Dandridge TN
with the dakota clip you still need to buy the 2 inch drop spindles and possibly the drop coils as well----unless you Z the frame...
It all depends on how you attach the Dakota clip.
[Re: Dabee]
#1570045
01/31/14 07:45 AM
01/31/14 07:45 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
hope u pull the trigger and by it too kool to pass by,,
disc brakes,,rusty hope or scare bird will have a kit with off the shelf parts
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#1570046
01/31/14 10:23 AM
01/31/14 10:23 AM
wedgeheaded
Friendly, WV
Yea, I think so too. My 75 Cordoba has a set of AR Torque Thrusts that would make it rock too.
[Re: savoy64]
#1570049
02/02/14 12:23 AM
02/02/14 12:23 AM
Dabee
Dandridge TN
thats why they call it Z-ing a frame---without a picture here it is basically putting a dakota frame on top of the original truck frame---makes a stair step thereby lowering the truck...
Like this
[Re: Dabee]
#1570050
02/02/14 11:19 AM
02/02/14 11:19 AM
moparpollack
Lil Herman
Lil Herman
85086
Like this
Lol!
[Re: fstfish66]
#1570054
02/15/14 06:06 PM
02/15/14 06:06 PM
wedgeheaded
Friendly, WV
Well, it's accademic now. I called sat morning and he'd sold it. I was stuck working 16s due to the cold weather and missed it. I'm still looking.
there is a web forum for mainly 1940 plymouth and dodges they also have a pilot house section on that forum you mayfind a truck for sale there www.p-15/d-24
Thanks. I hang out there some. They've been a big help.
