Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569846
03/01/14 03:57 PM
03/01/14 03:57 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Pulled the hood
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569847
03/01/14 03:58 PM
03/01/14 03:58 PM
Dreaming of the 808
Dreaming of the 808
Getting ready to pull the motor and trans
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569848
03/01/14 11:42 PM
03/01/14 11:42 PM
Dreaming of the 808
Dreaming of the 808
Ready for some 440 plucking
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569849
03/02/14 08:45 PM
03/02/14 08:45 PM
Dreaming of the 808
Dreaming of the 808
Motor and trans coming out
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569850
03/02/14 08:45 PM
03/02/14 08:45 PM
Dreaming of the 808
Dreaming of the 808
Different view
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569851
03/02/14 08:46 PM
03/02/14 08:46 PM
Dreaming of the 808
Dreaming of the 808
Completely out
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569852
03/02/14 08:47 PM
03/02/14 08:47 PM
Dreaming of the 808
Dreaming of the 808
Different angle
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569853
03/02/14 08:52 PM
03/02/14 08:52 PM
Dreaming of the 808
Dreaming of the 808
Car motor is out of, 69 Chrysler 300
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569854
03/02/14 08:56 PM
03/02/14 08:56 PM
Dreaming of the 808
Dreaming of the 808
Engine pad, E440' assembled 1-2-69, HP2, car was built 12-9-68 but this one is close enough for me
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569855
03/02/14 10:25 PM
03/02/14 10:25 PM
tennessee,usa
mattsmopars Online content
mattsmopars  Online Content
tennessee,usa
Looking good! Congrats on being able to work on the R/T it looks to be a very good car to restore!
Matt
Re: 1969 Coronet R/T Resurrection. [Re: mattsmopars] #1569856
03/09/14 01:52 AM
03/09/14 01:52 AM
Dreaming of the 808
Dreaming of the 808
440 ready for a bath
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569857
03/09/14 01:53 AM
03/09/14 01:53 AM
Dreaming of the 808
Dreaming of the 808
In progress
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569858
03/09/14 01:54 AM
03/09/14 01:54 AM
Dreaming of the 808
Dreaming of the 808
Almost clean
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569859
03/09/14 01:55 AM
03/09/14 01:55 AM
Dreaming of the 808
Dreaming of the 808
Mostly clean, I also pulled all the block freeze plugs and flushed out as much of the junk that I could
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569860
03/09/14 11:10 AM
03/09/14 11:10 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 1969 Coronet R/T Resurrection. [Re: OhioMopar] #1569861
03/10/14 03:34 AM
03/10/14 03:34 AM
Dreaming of the 808
Dreaming of the 808
Looks like the timing chain has jumped, bent push rods.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569862
03/10/14 02:02 PM
03/10/14 02:02 PM
tennessee,usa
tennessee,usa
I hope that doesn't turn out worse than the bent pushrods for you. The last 69 Bee I bought was supposed to be a running project. When I got to the point of working on it, it also had bent pushrods on number 1 and 3 cylinders. I got into it and it had dropped a valve on number 3 and busted the piston and the block. So needless to say I had to put a completely different engine in the car.
Matt
Re: 1969 Coronet R/T Resurrection. [Re: mattsmopars] #1569863
03/10/14 02:43 PM
03/10/14 02:43 PM
Dreaming of the 808
Dreaming of the 808
I hope that doesn't turn out worse than the bent pushrods for you. The last 69 Bee I bought was supposed to be a running project. When I got to the point of working on it, it also had bent pushrods on number 1 and 3 cylinders. I got into it and it had dropped a vlave on number 3 and busted the piston and the block. So needless to say I had to put a completely different engine in the car.
Matt
Pistons look good with just some light marks by a couple of valves. It was in a big Chrysler 300 so I'm guessing timing chain jumped and it died an easy death, nothing catastrophic. Bottom end looks good.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569864
03/10/14 08:17 PM
03/10/14 08:17 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Check the pan on the engine. They used to use nylon coated timing gears for a "quite chain". My 71 barracuda with a 383-2bbl had timing that was all over the map.
Pulled the pan and found it full of nylon chips. Pulled the timing chain cover and the nylon gear blank had razor sharp teeth as the nylon coating was gone. Substantial timing back lash.
Cleaned the motor best I could, put in a TRW double roller timing chain and sprocket set (all metal) and kept on going.
Re: 1969 Coronet R/T Resurrection. [Re: larry4406] #1569865
03/11/14 01:09 AM
03/11/14 01:09 AM
Dreaming of the 808
Dreaming of the 808
Timing chain was not the original one. Pan was debris free other than 20 year old sludge.
