Page 2 of 3 1 2 3
Re: 1962 W500 Barn Find [Re: Rhinodart] #1569305
01/27/14 01:56 PM
01/27/14 01:56 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks guys! I must have a freakin hole in my head for taking on this project but we need a water truck for fire suppression at our other house. We all know how much of a pain new stuff can be so I figured it would be better if I could fend for myself when something on the truck needs to be fixed.
For comparison I can buy a Kodiak with a water tank and pump for around 10k so that is my five year budget. I think we are going to try to get a split PTO for the t-case for a winch / H20 pump combo.
I'll probably need a few before this is done.
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569306
01/27/14 02:46 PM
01/27/14 02:46 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline
DusterJeff  Offline
Neat Truck..Is it rated at a 2 ton or 1 1/2 ton????
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: 1962 W500 Barn Find [Re: DusterJeff] #1569307
01/27/14 03:09 PM
01/27/14 03:09 PM
cleveland, tx
dodgzilla 1 Offline
dodgzilla 1  Offline
cleveland, tx
thats a beast. lovin it. . i need that so i can give it the dodgezilla name.
Re: 1962 W500 Barn Find [Re: dodgzilla 1] #1569308
01/27/14 05:10 PM
01/27/14 05:10 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that a great find. Dodoge sure knew how to tbuild them back then.
1981 Dodge D150 360 auto
Re: 1962 W500 Barn Find [Re: basketcase] #1569309
01/27/14 06:18 PM
01/27/14 06:18 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
There was a farmer around here that had one. I think it had a dump bed on the back. Was a 413 I think. As long as I've been alive it has set parked under a lean-to. He dies a few years back and after that the truck disappeared even though nothing else was moved or sold. Wish I knew what happened to it. Awesome find!!
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569310
01/27/14 06:40 PM
01/27/14 06:40 PM
hooziewhatsit Offline
Nice!
Re: 1962 W500 Barn Find [Re: hooziewhatsit] #1569311
01/27/14 10:35 PM
01/27/14 10:35 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
6.80 gears and a 5,000 rpm redline ....sounds like something needed for a certain small-block Mopar in the mid-south central part of FL .... iN oRdEr to keep it together
Re: 1962 W500 Barn Find [Re: dOoC] #1569312
01/27/14 11:31 PM
01/27/14 11:31 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
She is a little rough around the edges but still restorable.
That condition would be, "drop dead mint" here in PA where those things are rust buckets. Just saw a 68 or 69 W500 in a junkyard yesterday!
Re: 1962 W500 Barn Find [Re: pinkduster] #1569313
01/28/14 12:46 AM
01/28/14 12:46 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I hear you, that is the main reason I moved West. Did that truck have a steering wheel? I need a minty steering wheel. Also pedal rubber and a gas pedal. Geez here I go again another giant project lol.
I was thinking today and it sure is strange that Dodge put the same steering box in the W500 as the W100.
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569314
01/28/14 01:04 AM
01/28/14 01:04 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
Real cool rig, I've never seen a Rockwell front axle like that before.
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569315
01/28/14 01:10 AM
01/28/14 01:10 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I don't think so.
Re: 1962 W500 Barn Find [Re: NITROUSN] #1569316
01/28/14 01:17 AM
01/28/14 01:17 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I just looked in my part book and I think are are right. It must be this massive truck making the box so little.
Care to elaborate on your experience or just looking to be debby downer?
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569317
01/28/14 01:24 AM
01/28/14 01:24 AM
N
NITROUSN Offline
NITROUSN  Offline
N
While it might look similar the 500 should be different. That is a nice truck. Once up and running treat it gently. Parts are very hard to find. 500 series are kind of in a world of their own. 400 is lighter and 600 is heavier. A lot of 200 to 400 parts are the same and 600-800 a lot are the same. 500 just seems to be in the middle.
Re: 1962 W500 Barn Find [Re: NITROUSN] #1569318
01/28/14 01:33 AM
01/28/14 01:33 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Good info thank you sir. I am going to need to look at the steering box because it is VERY loose. The brake and clutch pedals have no pressure but that should be pretty straight forward to repair.
The second owner that I bought it from picked this truck up from the ODOT sale in Portland in 1968. It was originally a plow truck with a dump box. When the boys go it back to Klamath Co. they installed a backhoe on the back to clean out the ditch. Talk about a hard life!
The good news is that the backhoe is on a 1972 W600 in the same barn! Hopefully the owner was serious when he said we would have first dibs.
Sorry for getting on a bit of a ramble there. Is there any source for medium sized truck parts like this? I assume the differentials and t-case would be used in other applications.
Thank you again!
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569319
01/28/14 01:47 AM
01/28/14 01:47 AM
N
NITROUSN Offline
NITROUSN  Offline
N
New parts from the dealer network will be about zilch. Best to write down all tag information for reference. Parts are going to take some looking. Once you find a source don't forget where to find him. You have a very rare truck. Lots of people set them aside when a problem pops up due to the rarity of part sources.
I would check and fill every fluid level and grease every grease able part I could find.
Re: 1962 W500 Barn Find [Re: NITROUSN] #1569320
01/28/14 01:27 PM
01/28/14 01:27 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Great find. Martin @ Arizonaparts has some nos for these trucks.
Re: 1962 W500 Barn Find [Re: wally426ci] #1569321
01/28/14 11:26 PM
01/28/14 11:26 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you I will look him up. If the factory steering box rebuild doesn't pan out I'll have to go aftermarket. I'd hate to do that but this thing needs to do some work or it won't be practical for me to build.
Re: 1962 W500 Barn Find [Re: Jeremiah] #1569322
01/29/14 12:56 AM
01/29/14 12:56 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Bud Thorpe did my steering box for my 100 so you may want to hit him up. Search his name on his site as i have posted his info before. He is named powerwagon54 on sweptline.org forum. He is in Washington state.
Re: 1962 W500 Barn Find [Re: wally426ci] #1569323
01/29/14 01:36 AM
01/29/14 01:36 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Vintage Power Wagons in Farifield, Iowa may have some part too.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1962 W500 Barn Find [Re: Rhinodart] #1569324
01/29/14 02:18 AM
01/29/14 02:18 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks for the info.
I found a '62 W500 dump truck today. It's a runner and also for sale.
This is getting out of hand! I'm going to need some help from you guys.
Page 2 of 3 1 2 3
