Mocked up my dual line oil system today, look ok?
#1569174
01/26/14 09:16 PM
01/26/14 09:16 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I was going to just cap off one of the pick ups because of clearance issues up front with alternator belt but I picked up one of Milidon's oil pumps and a low profile 90 degree fitting and everything cleared so I mocked up the oil system today to see if I needed to make new lines or get new fittings but I think it may work with what I have.
I'm using a 400 block and a set of 906s just to check header clearance. The higher deck height on the RB block and raised exhaust ports on the 440-1s will just give it more clearance.
I'm using the Milodon 31161 9qt pan Milodon dual line pick up and hoses (used) Milodon 21815 aluminum dual line oil pump Muscle Motor's pump cover, discovered that the oil pressure relief hole wasn't threaded deep enough. Neither the stock or the Milodon fitting will seat to the flange, easy fix just one more thing to fix but still like it) Muscle Motor's oil pan gasket (reusable rubber coated steel lined and has steel bosses at the pan bolt holes to keep you from over tightening)
The lines don't touch the block, the pump, the motor plate or each other and there is room to run the dip stick tube between them.
Anyone have any concerns with this set up? Do I have the lines routed right so the pump won't loose prime?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Mocked up my dual line oil system today, look ok?
[Re: WadeMetzinger]
#1569186
01/27/14 01:05 PM
01/27/14 01:05 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Hemi-ITIS are those 1 way check valves? (To prevent the oil from draining back?)
What is meant by cavitation? Are you meaning that the Milodon pump's suction causes the supply lines to collapse? Or does the pump lose prime and sort of vapor locks even though they is oil in the lines it can't pull it? If your meaning that the lines collapse I may replace them with tephlon lined hoses just to be safe.
I also run a Master Lube accumulator system that I use to pressurize the oil system prior to starting and it also keeps the system pressurized if and when the oil pump looses prime in my old system but was thinking I wouldn't have that issue with the way I'm routing the lines with this oil system.
They are pre filters with screens in them.If something comes apart and gets in the oil pan,these will stop any large objects to get sucked into the oil pump and sent through the engine.They unscrew so you can check the screen for debris. These were originally recommended to me by Jimi Vignogna.
[Re: hemi-itis]
#1569187
01/27/14 01:32 PM
01/27/14 01:32 PM
Posts: 90 ok
mopdragster
ok
I'd prefer to run the back line under the front line like in Bigtimeauto's pic. Maybe gravity will help keep at least one line full of oil when sitting and for startup may help get pump primed and pressure sooner.
[Re: mopdragster]
#1569188
01/27/14 02:35 PM
01/27/14 02:35 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I prefer to have the lines take the "low way" from the pump to the pickups. Helps make sure that oil stays in line so you do not loose prime, at least thats how I feel.
[Re: rbkt65]
#1569190
01/28/14 02:12 AM
01/28/14 02:12 AM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
wade this is rick Woolsey buddy of guy from gateway with 64 polara wedge sled. is there going to be any possible concern with cavitation on this set up as garys 64 has been doing crazy things to bearings. we changed pans twice but machinist thinks cavitation may be problem. we have line run up over like yours. just asking. thanks rick
My thinking you are sucking air at a fitting(cracked) or at the swinging pickup. Could be a crack in an oil passage running to the mains.
