Australian belt drive timing system, anyone else using?
#1568829
01/26/14 12:51 AM
01/26/14 12:51 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I purchased this on Moparts, I think from Mr P-Body, and have been running it for the last 2 years with no issues at all. It seems to be a well designed system but I don't think I've ever seen or read where anyone else was using one so I thought I would post so e pictures of mine and give it thumbs up review So does anyone else use one of these? They work differently than the Jessel belt drive system, for one they use an idler pulley and an eccentric bolt to adjust the tension they also use torrington bearing on the cam pulley, which means that you use different timing cover gaskets to set the cam end play where Jessel uses shims. It's worked great for me and I would recommend them if your looking for belt drive timing system. Australian Muscle Parts
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Australian belt drive timing system, anyone else using?
[Re: WadeMetzinger]
#1568834
01/26/14 06:27 PM
01/26/14 06:27 PM
Posts: 2,937 A shed in England
Tig
A shed in England
I looked at getting one before we got the Jesel. It's a nice piece but the shipping costs from Aus were monumental!!
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: WadeMetzinger]
#1568836
01/26/14 07:29 PM
01/26/14 07:29 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
He doesnt make the Chrysler ones anymore.
RIP Monte Smith
[Re: CompWedgeEngines]
#1568837
01/26/14 07:34 PM
01/26/14 07:34 PM
Posts: 4,647 aotearoa
rebel
aotearoa
pfffft! buggar, i was hoping to buy another for my 470 motor.
#1568838
01/28/14 01:42 PM
01/28/14 01:42 PM
WadeMetzinger
Tulsa, Ok
I didn't know that either. I just ordered a new belt and replacement eccentric bolt from him last week and he didn't mention that...
[Re: rebel]
#1568840
01/28/14 03:07 PM
01/28/14 03:07 PM
Posts: 40 Harrison Township, Michigan
Hemi SS
i've been using one for 8-9 years now. great piece especially with the idler which a Jesel doesn't have. i'm now at the point that everytime i freshen the motor i can get the cam centerline perfect first time.
Jesel uses the idler with the raised cam version.
I have a new Jesel for standard cam location with extra belt if anyone is interested
[Re: WadeMetzinger]
#1568843
01/28/14 10:17 PM
01/28/14 10:17 PM
Posts: 1,162 s e mich
ro23car
s e mich
you can get the belts from amazon.
