Re: code 1688, time for a new pump.
[Re: johnzgarage]
#1568822
01/26/14 01:03 AM
01/26/14 01:03 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am not familiar with the codes anymore, but it may not be the pump. I found a list of the codes on the net before and I am sure you can, too. The prices may have come down, but when I changed my VP44 I thought I got a good deal at $1,200.00 exchange Bear in mind that was 4 or 5 years ago and like I said the prices may have come down because the VP44 is not the newest design now. I did mine myself and had never done more than oil changes to the Cummins before that. You can do it, too. There is lots of info out there about the job. Be sure to upgrade the lift pump if you have not already done it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: NITROUSN]
#1568824
01/26/14 01:25 AM
01/26/14 01:25 AM
Posts: 427 saint paul mn.
johnzgarage
saint paul mn.
You don't have a fuel pressure gauge? Your lift pump most likely died. With that being said you may of been killing your VP44 injection pump. Start with fuel pressure to the VP44 and go from there.
Well, I did put a new carter lift pump in about 15k ago and it has good transfer psi at the banjo. I wish it was just a lift pump, it would make my wallet feel alot better.
[Re: NITROUSN]
#1568827
01/26/14 02:13 AM
01/26/14 02:13 AM
johnzgarage
saint paul mn.
And how much psi is that?
Enough(13.5 psi ) to start start looking for I.P's
