code 1688, time for a new pump. #1568821
01/26/14 12:46 AM
01/26/14 12:46 AM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Just the other morning, I was warming up my 2000 ram 5.9 and I could hear a new strange noise, like a bearing squeal. It wasnt that loud or noticeable, so I took off and 20 miles later the pedal went dead . Now it wont start and I have code 1693, 1688 and 252 . I guess time for a new pump.
Who has the deal on vp44 pumps ? My target price is about $800 with the core.....or better. Could this be done ?
Re: code 1688, time for a new pump. [Re: johnzgarage] #1568822
01/26/14 01:03 AM
01/26/14 01:03 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am not familiar with the codes anymore, but it may not be the pump. I found a list of the codes on the net before and I am sure you can, too.
The prices may have come down, but when I changed my VP44 I thought I got a good deal at $1,200.00 exchange
Bear in mind that was 4 or 5 years ago and like I said the prices may have come down because the VP44 is not the newest design now. I did mine myself and had never done more than oil changes to the Cummins before that. You can do it, too. There is lots of info out there about the job. Be sure to upgrade the lift pump if you have not already done it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: code 1688, time for a new pump. [Re: johnzgarage] #1568823
01/26/14 01:05 AM
01/26/14 01:05 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You don't have a fuel pressure gauge? Your lift pump most likely died. With that being said you may of been killing your VP44 injection pump. Start with fuel pressure to the VP44 and go from there.
Re: code 1688, time for a new pump. [Re: NITROUSN] #1568824
01/26/14 01:25 AM
01/26/14 01:25 AM
saint paul mn.
saint paul mn.
Well, I did put a new carter lift pump in about 15k ago and it has good transfer psi at the banjo. I wish it was just a lift pump, it would make my wallet feel alot better.
Re: code 1688, time for a new pump. [Re: johnzgarage] #1568825
01/26/14 01:40 AM
01/26/14 01:40 AM
N
NITROUSN Offline
NITROUSN  Offline
N
And how much psi is that?
Re: code 1688, time for a new pump. [Re: NITROUSN] #1568826
01/26/14 02:06 AM
01/26/14 02:06 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I havent seen any VP44's going for 800 bucks. the cheapest Ive seen are right a round a grand + or - 50 bucks.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: code 1688, time for a new pump. [Re: NITROUSN] #1568827
01/26/14 02:13 AM
01/26/14 02:13 AM
saint paul mn.
saint paul mn.
Enough(13.5 psi ) to start start looking for I.P's
Re: code 1688, time for a new pump. [Re: johnzgarage] #1568828
01/26/14 02:17 AM
01/26/14 02:17 AM
N
NITROUSN Offline
NITROUSN  Offline
N
