Re: All new brakes, low and hard pedal
[Re: ChallengerGary]
#1568424
01/25/14 06:27 PM
01/25/14 06:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Let us know.
I hate installing other people's supplied parts almost as much as I hate buying something someone else modified.
Because now you have to figure out why the thing doesn;t work and it may very well be the kit that was supplied, which puts you in the middle of the customer and the supplier, both of which are going to point at you.
[Re: Lefty]
#1568428
01/26/14 05:40 PM
01/26/14 05:40 PM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
With the engine off, pump the brake pedal 10 times. Push on the brake pedal and start the engine - You should feel the pedal drop under your foot. If not the booster/vacuum source is bad or the MC to Booster interface has a problem.
It drops a little. The main thing seems to be there is not enough travel in the pedal.
#1568429
01/27/14 01:37 PM
01/27/14 01:37 PM
Posts: 3,895 Oregon
hooziewhatsit
Can you see any daylight between any of the pads and rotors?
If there is, that could be taking up most of your stroke.
[Re: hooziewhatsit]
#1568430
01/28/14 01:23 PM
01/28/14 01:23 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
Push rod in booster too short or linkage at brake pedal too short?
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
#1568434
02/04/14 02:00 AM
02/04/14 02:00 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
do you have an adjustable valve on the rear line to adjust the rear brakes from overpowering the fronts?
[Re: dangina]
#1568436
02/04/14 11:10 AM
02/04/14 11:10 AM
ChallengerGary
Not yet. Guess that is the next step...
