1969 Coronet R/T referance phots needed #1568303
01/25/14 01:02 AM
01/25/14 01:02 AM
Well, the bodymen are asking for some direction regarding holes that need to be drilled in the body of my 69 Coronet R/T. I am hoping you guys can help me out with the following pictures or mesaurements. Thanks for any help in advance.
-Fender mounted turn signal indicator holes in the top of each fender.
-N96 ramcharger hood cable hole in firewall.
*MOST IMPORTANT* - 1/4 panel side scoop holes.
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568304
01/25/14 02:23 AM
01/25/14 02:23 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I can get you the first 2 tomorrow, my 500 vert has the turn signals and my R/T has the N96 cable, I don't have a car with the side scoops
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568305
01/25/14 02:24 AM
01/25/14 02:24 AM
Thanks a lot!
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568306
01/25/14 03:47 AM
01/25/14 03:47 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Investigate before you take my word for it, but I don't believe you could get N96 and the fender turn signals on a 69 Dodge. The passenger-side scoop blocks your view of the signal, hence they weren't really compatible. I think you could get them together on a Plymouth.
Darren
Re: 1969 Coronet R/T referance phots needed [Re: Ludington1] #1568307
01/25/14 04:36 AM
01/25/14 04:36 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NO (zero) 1969 Super Bees or Coronet R/Ts FACTORY OPTIONed with both "RAMCHARGER" hood (N96) & fender turn signal indicators (L31).
Re: 1969 Coronet R/T referance phots needed [Re: 6bblgt] #1568308
01/25/14 06:27 AM
01/25/14 06:27 AM
My car originally was optioned with fender mounted turn signals, but not a ramcharger hood. The original fenders were scrap and I didnt take measurements of the holes unfortunately. I thought that I had heard before not being able to have both options together but I have seen many Bees and R/Ts with them together......
Doesnt mean they were born that way of course I suppose.
Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568309
01/25/14 06:43 AM
01/25/14 06:43 AM
MI
chapdog105 Offline
chapdog105  Offline
MI
Digging that convertible!
David,
I'm heading over to Donny's to pick-up some parts tomorrow.
Looking forward to seeing the progess on your Bee.
Re: 1969 Coronet R/T referance phots needed [Re: chapdog105] #1568310
01/25/14 07:19 AM
01/25/14 07:19 AM
Alex, I heard that my car is finally on the rotisserie. After 3 years of body shop hell, its a good feeling. Nothing like your story though. Your car has to be pretty far along by now huh?
BTW, my car is an R/T, not a Bee
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568311
01/25/14 01:43 PM
01/25/14 01:43 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I was in a similar postion several years ago with my '70 Swinger 340. I liked the look of them and was thinking of adding them. The sales brochure showed a Swinger 340 with fender mounted turn signals (hood scoops were standard equipment) but the dealer data book and price book said they were not available on the Swinger 340.
From the dealer price books at hamtramck-historical
1969 Coronet
1970 Dart
Re: 1969 Coronet R/T referance phots needed [Re: moparfan53] #1568312
01/25/14 02:48 PM
01/25/14 02:48 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Dave here is an underhood shot of my old Coronet, I didn't have fender lights due to the Ram Charger and it was a factory scoop car so don't have any measurements on that.
Ron
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568313
01/25/14 02:51 PM
01/25/14 02:51 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thanks a lot!
I can't get you the pics till Monday morning, I have to unbury the R/T and won't have time till then
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568314
01/25/14 03:11 PM
01/25/14 03:11 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is a thread with some scoop info;
https://board.moparts.org/ubbthreads/showflat.php?Number=7589105
Re: 1969 Coronet R/T referance phots needed [Re: moparfan53] #1568315
01/25/14 04:15 PM
01/25/14 04:15 PM
Thanks for the help everybody
Re: 1969 Coronet R/T referance phots needed [Re: 6bblgt] #1568316
01/27/14 12:18 AM
01/27/14 12:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dan, does this also apply to the A12 lift off hood cars as well?
Re: 1969 Coronet R/T referance phots needed [Re: 6bblgt] #1568317
01/27/14 01:52 AM
01/27/14 01:52 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
WHY?
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568318
01/27/14 01:54 AM
01/27/14 01:54 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Was it because the driver couldn't see the right fender mounted light because of the height of the right hood scoop. If so then for sure there would be no way with an A12 hood either...................but maybe you could with the A12 hood scoop versus the ramcharger single that was more outboard and inline with the driver's sightline?
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568319
01/27/14 08:43 AM
01/27/14 08:43 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's why I question the NA N96 combo..... we all know some cars exist with NA options/combos/etc
Re: 1969 Coronet R/T referance phots needed [Re: DAYCLONA] #1568320
01/27/14 10:12 AM
01/27/14 10:12 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
I found this some time ago. Other than the sloppy detail dimensions (edge of hole vs center of hole), it is accurate.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 1969 Coronet R/T referance phots needed [Re: Big D A12] #1568321
01/27/14 09:33 PM
01/27/14 09:33 PM
Hope this helps.
That is perfect. Thanks a lot.
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568322
01/27/14 10:23 PM
01/27/14 10:23 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Air grabber #1
