MSD ready to run distributor added power #156820
11/25/08 11:13 PM
11/25/08 11:13 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
Anyone dot an idea how much hp something like this adds to a 318 running on pump gas. I've been is discussions with a buddy that swears that the old mopar ecm delivers all the spark you need. I disagree thinking that with today's water gas you need something hotter. But would like to hear if anyone has run a side by side comparison on hp boost.
Re: MSD ready to run distributor added power [Re: Rick57] #156821
11/25/08 11:17 PM
11/25/08 11:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you slap one on right out of the box, I don't think you'll gain any power. The whole point of the MSD ready 2 run is everything inside of it is new and easily tunable. You can't easily tune the vacuum advance in a stock distributor. It can be done, but it's not the easiest to do. Plus the msd unit gets rid of all that 30 year old, worn out stuff under your hood and replaces all with new. Now a properly tuned msd will outperform a stock setup, but a well tuned stock setup will perform on par with a well tuned msd.
Re: MSD ready to run distributor added power [Re: DaytonaTurbo] #156822
11/25/08 11:22 PM
11/25/08 11:22 PM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
DaytonaTurbo
thanks
nice satellite I am working on a 74 also but with a 318 love that body style
Re: MSD ready to run distributor added power [Re: Rick57] #156823
11/25/08 11:27 PM
11/25/08 11:27 PM
Manitoba, Canada
Manitoba, Canada
Thanks man and good luck.
