Page 2 of 3 1 2 3
Re: Hemi ID Question [Re: 70mopes] #1568204
01/25/14 09:50 PM
01/25/14 09:50 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
SPD is 1/22.
The six digits after the "G" on the front top pad do not pertain to the last six of the VIN.
Looks like a service replacement block.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568205
01/25/14 09:51 PM
01/25/14 09:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you could see the sides of the block you will likely find one of these somewhere.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568206
01/25/14 09:52 PM
01/25/14 09:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tags were often ripped away but the rivets (or just the rivet hole) often remained.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568207
01/25/14 09:56 PM
01/25/14 09:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The tag
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568208
01/26/14 12:34 AM
01/26/14 12:34 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Here's a 68 pad, block was cast in 1966
Same stamping on my motor out of my 1971 Cuda. A T W. If the serial number on the front pad is not the same as the car it is in you would have to do a lot of research to see who stamped the numbers and letters on the block. There could be all kinds of conclusion to this mystery of the block. It could of been a counter block or maybe someone got another short block or long block from another car or from another builder to put in this car when the motor got sick. Who knows unless you were involved.
1971 HEMI E BODY REGISTRY
Re: Hemi ID Question [Re: hemicar1971] #1568209
01/26/14 01:15 AM
01/26/14 01:15 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It appears the OP has photographed a replacement (at a minimum) block that was machined in '69 then assembled & painted "race HEMI orange" (not the original color for a '70 Road Runner) then rebuilt/repaired/other & painted "street HEMI orange" & that paint job looks to be decades old. The additional numbers stamped on the top pad (G193539) are reference numbers to an invoice/customer/job number/other somewhere along the way.
Re: Hemi ID Question [Re: 6bblgt] #1568210
01/26/14 01:30 AM
01/26/14 01:30 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Looks like the "A" stands for a 20 over size piston. If Chrysler stamped the "A" on the block of my Cuda then it is a 429 Hemi just like a Ford Hemi. I believe when the motor was built the last time the builder stamped the block with the "A" knowing exactly what it was for for future rebuilding information.
Re: Hemi ID Question [Re: hemicar1971] #1568211
01/26/14 01:56 PM
01/26/14 01:56 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
am I wrong in thinking that that block may have a history that *could* include grinding off of the pad #'s and re-stamp? The machine marks suspicious.
Re: Hemi ID Question [Re: srt] #1568212
01/26/14 02:23 PM
01/26/14 02:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They look factory to me
Concerning the Race Hemi Orange paint (which looks original) all 64-68 Hemis and SOME 69 Hemis were painted Race Hemi Orange. So, it's likely that it was built before the paint color change. As stated, it's most likely a typical service replacement engine of the era that was put into inventory and used when needed as a warranty replacement or simply sold over the counter, etc. The other stampings were added after the fact by whomever, without a paper trail the rest is pure speculation.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568213
01/26/14 02:27 PM
01/26/14 02:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If it is a "service replacement" or "over-the-counter" sold piece, the factory wouldn't have painted it.
Re: Hemi ID Question [Re: 6bblgt] #1568214
01/26/14 02:52 PM
01/26/14 02:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Good point Dan, makes me wonder if there were exceptions to that?
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568215
01/26/14 03:02 PM
01/26/14 03:02 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
How much, or little info is on the lower pad for a (March '69 vintage) "block" VS. "short block assembly"?
To me, the single date screams: when this left Chrysler it was a bare machined block ONLY.
Re: Hemi ID Question [Re: 6bblgt] #1568216
01/26/14 03:13 PM
01/26/14 03:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As most have seen, this is how most (if not all) replacements looked, I just wonder if there were other ways they were delivered.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568217
01/26/14 03:15 PM
01/26/14 03:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
But as far as the date on the pan rail extension, you might be right Dan, but I've seen some earlier blocks (originals installed in cars) with similar dates, so I can't comment with certainty on that one.
This tag was on a block installed into a 66 Hemi car, it was said to have been purchased as a replacement from Kieth Black back then. I can't say for sure but it appears that it was painted at the factory, either that or someone took the time to mask off the tag before painting and installing the engine.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568218
01/26/14 03:17 PM
01/26/14 03:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And in this case it looks as if someone restoring thier car wanted to preserve the appearance of the tag and masked it before painting, but that's a guess, it could have been painted at the factory before the tag was added? I wasn't there so I don't know.
Re: Hemi ID Question [Re: 6bblgt] #1568219
01/26/14 03:39 PM
01/26/14 03:39 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
What is needed to be found out to start a search is just what was changed on this motor. Was there a replacement of a block only, short block or long block or complete motor. What version or year is the intake now on the motor. What year are the carbs and is there anything that is a different year to the body on the motor. How does anyone know if there was a complete total change of the motor without more information and maybe taking a look at some date codes on each part of the motor.
Back in the day you would rebuild your race motor every off season. Bearings, rings and updates every winter. Anytime I do any kind of build or rebuild of a motor every thing is taken down to bare metal. Blocks and heads go into the Hot Tank and cleaned. This would mean all paint would be eliminated from the cast iron parts such as the block. So if paint was left on the block then did someone just do a CIL rebuild on the motor by just painting everything. So did the complete motor get the paint of did just some pieces such as the block.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568220
01/26/14 04:39 PM
01/26/14 04:39 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
There's orange paint on the tag, so that leads me to think it wasn't
painted at the factory...
Re: Hemi ID Question [Re: Triggerfish] #1568221
01/26/14 04:59 PM
01/26/14 04:59 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The oil pan is black, not sure why and not sure if it is factory or aftermarket or altered factory pan. The Oil Pan bolts, is that bluish on them and the type of bolts? The only way to know more is to have someone go with the OP and look at all the numbers and colors and what ever that can give more information. Kind of a nice post for learning about different stuff on a Motor and how things were put together.
Re: Hemi ID Question [Re: ScottSmith_Harms] #1568222
01/26/14 05:27 PM
01/26/14 05:27 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
When i had these Hemi engines, along with a NOS hemi short block, in the crate, none of them were stamped on the ID pad.
They did have the WT stamp, along with one or two, letters "B" on the pad.
And by the way, the NOS shortblock was unpainted.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Hemi ID Question [Re: hemi71x] #1568223
01/26/14 06:40 PM
01/26/14 06:40 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I agree on the not painted part. This block is one of the "Over the Counter" Hemi blocks. It has the WT stamp and two "B"s. It was pulled out of the Chrysler box and had been drop-shipped from Keith Black sometime around 1971. The block is a 5-19-69 casting and 4-24-702 on the pan rail.
Page 2 of 3 1 2 3
