2004 Dodge 2500 engine interchange #1568172
01/24/14 10:47 PM
01/24/14 10:47 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
This truck is close to me and has been advertised for 2 months.Not sure about engine but it is not a Hemi or Cummins. I believe it is a 5.9 gas.2004 2500 regular cab 2wd. Truck looks real clean all the way around.It has a nice aluminum ladder rack,an in bed tool box and an aluminum tool box behind cab.The Problem is there is a hole in the block and my question is: What year 5.9 will bolt in? Considering buying,repairing and reselling or possibly keeping. Thanks!
No one knows what years will work?
Re: 2004 Dodge 2500 engine interchange [Re: 68GTS383] #1568173
01/25/14 08:55 PM
01/25/14 08:55 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Check Car-parts.com for any engines available, that will give you the interchange, by looking at the listings.
Re: 2004 Dodge 2500 engine interchange [Re: 68GTS383] #1568174
01/26/14 04:14 AM
01/26/14 04:14 AM
Ohio
john55 Offline
john55  Offline
Ohio
I just checked Alldata, in 2004, 2500 4x2, only 2 engines are 5.7 gas hemi, or 5.9 diesel
The Plymouth Win You Over Beat Goes On
Re: 2004 Dodge 2500 engine interchange [Re: 68GTS383] #1568175
01/26/14 03:36 PM
01/26/14 03:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I believe you could get the 4.7 the hemi 5.7 the 8.0 v-10 and the 5.9 cummins.
Re: 2004 Dodge 2500 engine interchange [Re: NITROUSN] #1568176
01/26/14 05:49 PM
01/26/14 05:49 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
I have only seen pics of the truck(150 miles away) and no hemi script or engine pics so I am sort of guessing. It would make a nice work/tow vehicle if repairs weren't too costly.Ad says hole in the block!
Re: 2004 Dodge 2500 engine interchange [Re: NITROUSN] #1568177
01/26/14 06:19 PM
01/26/14 06:19 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Nope, like said above, only the 5.6 Hemi and the 5.9 Cummins. The V10 was axed in 2003 and the 4.7 was for half tons only.
JB Rhinehart, Realist
A-Body's RULE!
Re: 2004 Dodge 2500 engine interchange [Re: Rhinodart] #1568178
01/27/14 09:33 AM
01/27/14 09:33 AM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
The last year for the 5.9 V8 was 2002.
