Alternator / Eddie Head Interference #156783
11/25/08 09:16 PM
11/25/08 09:16 PM
MARYLAND
69Cuda340S Offline OP
MARYLAND
The back of the alternator hits the cylinder head when I try to rotate it into position. I am using the stock '69 brackets which line up with the stock water pump pulley. Anyone ever run into this and if so what was the solution? This is a AC car. Would a non AC alternator be smaller in the back?
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156784
11/25/08 09:18 PM
11/25/08 09:18 PM
MARYLAND
MARYLAND
Another
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156785
11/25/08 09:34 PM
11/25/08 09:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Virtually the same thread is already running...
https://board.moparts.org/ubbthreads/show...rue#Post4838149
Re: Alternator / Eddie Head Interference [Re: 1_WILD_RT] #156786
11/25/08 09:37 PM
11/25/08 09:37 PM
MARYLAND
MARYLAND
Thanks for the heads up.
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156787
11/25/08 09:40 PM
11/25/08 09:40 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I milled down the back of my housing to make it fit.The 69 and earlier stuff is closer to the head than the later .
Re: Alternator / Eddie Head Interference [Re: Scamp408] #156788
11/25/08 10:09 PM
11/25/08 10:09 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I just bought one of those generic chrome swing arms from Advance auto parts for the lower adjustment, and got a longer belt.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Alternator / Eddie Head Interference [Re: 70dart360] #156789
11/25/08 11:37 PM
11/25/08 11:37 PM
MARYLAND
MARYLAND
I think an alternator like this would have more clearance on the back:
http://chucker54.stores.yahoo.net/oem50amprbae.html
Can I get a "round back" from a local parts store or are they just going to give me another "square back" type alternator?
Scamp 408, you run the early style water pump, what does the back of your alternator look like?
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156790
11/25/08 11:47 PM
11/25/08 11:47 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I haven't checked parts houses in a few years, the round back use to be avalible, Mancini lists the round back as the same from 64-74 when there are actually two styles a single wire (69 & earlier)that uses a pulsed 12v signal to control the output & a two wire (70 & later) that uses a 12v input then a pulsed ground...
Re: Alternator / Eddie Head Interference [Re: 1_WILD_RT] #156791
11/25/08 11:58 PM
11/25/08 11:58 PM
i just got a round back alt for my cuda from oreillys. the thing is, ts hit or miss. they may sell them both under the same part number.
Have them send in 3 and take a look at what you get or if you are buddies with the parts guy, maybe he can put in a request at the warehouseto send a roundd back and they can hand pick it for you
Re: Alternator / Eddie Head Interference [Re: 1_WILD_RT] #156792
11/26/08 12:06 AM
11/26/08 12:06 AM
MARYLAND
MARYLAND
This thread has some good pictures of round back and square back alternators:
https://board.moparts.org/ubbthreads/show...rue#Post4742889
I definitely think a round back type would solve my problem. I'd like to buy one locally if possible.
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156793
11/26/08 01:02 AM
11/26/08 01:02 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Their are 2 diff square back .1 you can mill down to fit the other you cant.The 1 in the pic from other post will work if you mill it.It has to do with the round part by the square.If you still need I will get pics tommorrow.
Re: Alternator / Eddie Head Interference [Re: Scamp408] #156794
11/26/08 07:42 AM
11/26/08 07:42 AM
MARYLAND
MARYLAND
Paul, please get me a pic when you get a chance. I am looking at mine and it can't be milled. Bill
Re: Alternator / Eddie Head Interference [Re: 1_WILD_RT] #156795
11/26/08 02:14 PM
11/26/08 02:14 PM
MARYLAND
MARYLAND
If you look up the PowerMasters alternator on Summits web site you can down load the instructions and this is what they say:
"Note that the Powermaster alternator is a double field unit that will work with both double field
and single field type external regulators. If your vehicle has two small field wires, they should
be connected to the FLD terminals on the back of the alternator. These wires are interchangeable, so either wire can be connected
to either FLD terminal. If your vehicle has one small field wire, connect it to either FLD terminal on the alternator. Then, using
a short 16 AWG or larger jumper wire, ground the remaining FLD terminal. Some models have a ground stud on the back
alternator case; this or any other bare metal grounding point will be sufficient."
Re: Alternator / Eddie Head Interference [Re: 69Cuda340S] #156796
11/26/08 02:33 PM
11/26/08 02:33 PM
AndyF Offline
AndyF  Offline
The 60 amp Denso alternator fit the Eddy heads just fine. Mancini Racing sells the complete kit to convert over to the slightly smaller Denso setup.
Re: Alternator / Eddie Head Interference [Re: AndyF] #156797
11/26/08 06:08 PM
11/26/08 06:08 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Pics.
Re: Alternator / Eddie Head Interference [Re: Scamp408] #156798
11/26/08 06:08 PM
11/26/08 06:08 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
pics
Re: Alternator / Eddie Head Interference [Re: Scamp408] #156799
11/26/08 11:52 PM
11/26/08 11:52 PM
MARYLAND
MARYLAND
Thanks for posting pics. A friend of mine knows a retired alternator rebuilder who is going to put together a single groove round back alternator for me. That should fit with room to spare.
I have also heard that some square backs don't stick out as much as others.
