Who makes the best carburetor base gaskets? #1567811
01/24/14 01:05 AM
01/24/14 01:05 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
I ask this question because I have had horrible luck with the gasket I have been trying to run and keep running because I can get them cheap and locally. I run a 1 inch 4 hole phenolic carburetor spacer on top of my manifold and I run a quick fuel super street series 680cfm vaccum secondary carburetor.
I run a standard open gasket on top of my manifold and under my spacer, and then I run a 4 hole gasket on top of my 4 hole spacer nd underneath my carburetor. The gasket I have been running and having issues with is the Mr Gasket 55 4 hole gasket.
They last for about 2 or 3 months and then there is a vaccum leak at the front corner, its like the seal just disappears, you can see the seal on the rest of the gasket except in the passenger front corner.
Are these gaskets just junk? And if so what are some good gaskets to try? I can always tell when the gasket has lost it's seal my idle becomes unstable and I can hear and feel miss fires. I have had this happen 2 or 3 times in the last year. All I can figure is these gaskets just suck, or carburetor base gaskets require changing a lot more then I would have thought.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567812
01/24/14 01:19 AM
01/24/14 01:19 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Superformance makes the best gaskets for most of your needs. His name is Greg and his handle here on Moparts is roadhazard.
Gus
64 Plymouth Savoy
Dana 60
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567813
01/24/14 01:24 AM
01/24/14 01:24 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Superperformance, sponser here Great gaskets top notch Mark
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567814
01/24/14 01:47 AM
01/24/14 01:47 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
X 3 on Greg at Superformance. I used his carburetor base gaskets on a Carburetor test session for an article. Several carbs with the same base gasket and one under the throttle linkage adapter. No sticking and sealed well after many R and R sessions.
Keith
Re: Who makes the best carburetor base gaskets? [Re: Dunnuck Racing] #1567815
01/24/14 01:53 AM
01/24/14 01:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Have you checked your spacer to see if its warped ?
I am truckless..
Re: Who makes the best carburetor base gaskets? [Re: 340SHORTY] #1567816
01/24/14 02:35 AM
01/24/14 02:35 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
My thought exactly. If it's always the same corner...
It's Swifty! Swifty, you toad sucker!
Re: Who makes the best carburetor base gaskets? [Re: zrxkawboy] #1567817
01/24/14 02:02 PM
01/24/14 02:02 PM
My last Felpro thick base gasket, the 4 brass inserts in the corner holes were a bit too tall & were causing a vac leak. I tamped em down slightly & that took care of that. As said if the same spot is leakin I'd do a close visual.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567818
01/24/14 06:36 PM
01/24/14 06:36 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
X4 on Superformance Gaskets.They are the best.
Nautilus Racing-
Re: Who makes the best carburetor base gaskets? [Re: Chris2581] #1567819
01/24/14 08:32 PM
01/24/14 08:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
X 1,000,000,000 on Superformance Products
Hey thanks for all the votes of confidence guys, much appreciated!! We're happy that your satisfied with the products
As stated above check all your surfaces to be sure they are flat and true.
To see our full line gasket catalog please click the link in my signature line. Once on our website you can also see a list of stocking distributors.
Re: Who makes the best carburetor base gaskets? [Re: roadhazard] #1567820
01/25/14 02:20 AM
01/25/14 02:20 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
I never thought about the spacer being warped because it's basically brand new , it only has like 4 or 5 thousand miles on it. But it makes sense. I have a 1/2 4 hole phenolic spacer, maybe I should run that one instead. How do I check the spacer for being warped?
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567821
01/25/14 05:19 AM
01/25/14 05:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
put a sheet of fine sandpaper on something real smooth. hold the spacer down in the middle. work the spacer around in a figure 8 motion. look for spaces that are not being scuffed.
I am truckless..
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567822
01/25/14 12:07 PM
01/25/14 12:07 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Super performance is #1! Their site is on line.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567823
01/25/14 12:26 PM
01/25/14 12:26 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Check for flatness using a straight edge, metal ruler, piece of bar stock, whatever just as long as it's straight and flat.
Check corner to corner, side to side and catty corner. Top and bottom, also check the intake flange and carburetor base plate.
In response to your PM here is a link to the catalog. Open the catalog and scroll down until you get to the carburetor gaskets. All the info you should need for them is there. Keep scrolling down for the price sheet.
http://www.superformanceproducts.com/catalog.php
If you would like to purchase some click on the "Distributors" tab and choose from the links where you would like to purchase them from.
Any questions just ask
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567824
01/25/14 12:39 PM
01/25/14 12:39 PM
Set it on a pane of glass. EDIT Also use it to do your figure 8 sandpaper sanding if needed
Re: Who makes the best carburetor base gaskets? [Re: RapidRobert] #1567825
01/28/14 01:30 PM
01/28/14 01:30 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
So I grabbed a few sheets of 220 grit sand paper and placed them on a big piece of glass and started moving the spacer around in a figure 8 motion and some of the spacer was being sanded and some of it wasn't being sanded. I'm guessing the spots that were being sanded were the high spots?
Anyways I moved it around in a figure 8 motion a few times. Do you think it is straight enough now? I don't have a straight edge but I do have a ruler, whats the best way to tell if it's straight after sanding it in a figure 8 motion?
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567826
01/28/14 02:46 PM
01/28/14 02:46 PM
(1) yes (2) keep sanding till all (or almost all) of the base is being touched by the paper. Finish with some finer grit than 220. keeping it parallel with even force is the key.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567827
01/28/14 02:50 PM
01/28/14 02:50 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes the parts that were being sanded were high spots.
"Is it straight enough now?"
Have no clue...... I can't see it
Use the ruler and a .005" feeler gauge. Set the edge of the ruler on the spacer and try to fit the feeler gauge under it. Try this on the piece of glass first to be sure the ruler is straight
Also check your manifold and carb base
Re: Who makes the best carburetor base gaskets? [Re: roadhazard] #1567828
01/28/14 05:20 PM
01/28/14 05:20 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
well I have sanded on a piece of glass in a figure 8 motion and I have grabbed my ruler and put the ruler on it's edge and I have .006 feeler gauge and I cant fit the .006 feeler gauge under the ruler. There are a couple tiny spots where there is still some shiny black as opposed to how the rest of the spacer looks since being sanded.
I figured I would continue to sand in a figure 8 motion until there are no shiny black spots and double check it with the ruler and feeler gauge and if I cant fit the feeler gauge under the ruler then I will consider it flat, at least flatter then it was.
Am I doing this correctly?
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567829
01/28/14 06:14 PM
01/28/14 06:14 PM
I'd say you are in real good shape. Spacers are wide & the gasket/cement will take care of anything that ain't dead on perfectly flat & you're way better then "close". As said check the other flat surfaces as it just takes one warped one to effect a leak
Re: Who makes the best carburetor base gaskets? [Re: RapidRobert] #1567830
01/28/14 06:32 PM
01/28/14 06:32 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
dam well I sure hope my carburetor isn't warped, it's brand new and doesn't even have a thousand miles on it. It's a quick fuel super street series supposes to be made of good billet aluminum. And I have never over tightend the carburetor nuts. I always torque them to 8 ft lbs. I sure hope the carburetor isn't warped, I would probably cry. paid 560 bucks for that thing.
