Any info on RetroTech performance tunnel ram? #1567753
01/23/14 10:19 PM
01/23/14 10:19 PM
Middletown, Ohio
Joes66dart Offline OP
Middletown, Ohio
I came across a retroteck sheet metal tunnel ram and I have never heard of them. I was hoping someone could give me some feedback there intakes. I tried looking them up but found no info at all on them. The one I found is a standard port window witha duel 4150 top
Re: Any info on RetroTech performance tunnel ram? [Re: Joes66dart] #1567754
01/24/14 12:34 AM
01/24/14 12:34 AM
I'm sure that is a fabricated tunnel ram, correct? If so I bought a used one several years back for a RB with M.W. ports, it is on a motor now and it worked great on the dyno and at the track I couldn't find any info on them back then either
Re: Any info on RetroTech performance tunnel ram? [Re: Cab_Burge] #1567755
01/24/14 01:13 AM
01/24/14 01:13 AM
Middletown, Ohio
Middletown, Ohio
Yes it is a fabricated tunnel ram. Im looking to use it on a 470 lowdeck with a set of stage vi heads. The only info i have found on them is older post by Cab about using one
Re: Any info on RetroTech performance tunnel ram? [Re: Joes66dart] #1567756
01/25/14 10:54 PM
01/25/14 10:54 PM
HR3128 Offline
HR3128  Offline
Mike at Muscle Motors may be able to provide some info. I know he used some of their intakes in the past.
