400 blocks is there a big difference #1567710
01/23/14 07:34 PM
01/23/14 07:34 PM
cheshire, ct
davesmopars Offline OP
cheshire, ct
1970 to 10 of 71 castings, are these the best???
thanks for any help.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 400 blocks is there a big difference [Re: davesmopars] #1567711
01/23/14 09:13 PM
01/23/14 09:13 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The last 3 numbers of the casting number will be 230. And there are 230 casting blocks without the thick main webs. You have to look. But you still need to sonic check. Older blocks seem to have more core shift. I would not worry much about year and go with the one that sonic checks the thickest.
Re: 400 blocks is there a big difference [Re: davesmopars] #1567712
01/24/14 02:13 PM
01/24/14 02:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW my 400 block came out of a 72 truck and the sonic #`s were decent and has been goin strong for 13+ years.............
Re: 400 blocks is there a big difference [Re: davesmopars] #1567713
01/24/14 04:22 PM
01/24/14 04:22 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
I sought out a 230 casting in that date range that most recommend - pre 10/71, and it sonic checked about the same as two later ones I've recently bought pretty cheap. From looking at the webbing of both types, I feel any 400 block will probably have similar life expectancy in a street/strip stroker like I'm planning.
If I was to step up the power a significant amount I'd definitely go with an aftermarket low deck block.
Re: 400 blocks is there a big difference [Re: 451Cuda] #1567714
01/24/14 05:00 PM
01/24/14 05:00 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
From the research that I have done any 400 block would be a better choice for rigidity than any 440 block out there from a stock factory block standpoint, as long as they sonic good.jmo
Re: 400 blocks is there a big difference [Re: dartman366] #1567715
01/25/14 02:03 PM
01/25/14 02:03 PM
X2. If a stroked "B" will get you the cubes you want then it's a better choice (my limit is 470 which is using an offset ground 440 crank) including it being lighter & a MUCH better fit in an A body. If more cubes are needed then go with the RB block, my next one is going to be a 535 (30 over 440 block) . Not sure whether to get a kit (440 source maybe) or an Ohio crank/some eBay chebby rods/& the KB pistons for that
Re: 400 blocks is there a big difference [Re: dartman366] #1567716
01/25/14 02:06 PM
01/25/14 02:06 PM
Maryville tn
67coronetman Offline
Maryville tn
Hmmmmm . ??
Old car are me......
Re: 400 blocks is there a big difference [Re: 67coronetman] #1567717
01/25/14 02:59 PM
01/25/14 02:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Someone did a bunch of sonic checks on a number of 400 blocks spread out over the production run and the old "myth" of early blocks being better didn't seem to hold up. Ah here it is
http://440source.com/blockinfo.htm
Read and decide for yourself.
Don't be the exception.
