Tool for 8.75 housing seal removal #156771
11/25/08 09:06 PM
11/25/08 09:06 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
What's the best way to remove the axle housing seal from an 8 3/4 housing? Is there a specific tool for this?
Re: Tool for 8.75 housing seal removal [Re: 68Bullit] #156772
11/25/08 09:13 PM
11/25/08 09:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
As you slide the axle out hole the flanged end towards the rear of the car and slide the splined end against the inside of the housing till it hits the seal and pry rearward with the axle and the seal will come out on the end of the axle. No special tools needed. It may not work for you the first time but it is a very simple way to take out the seal and it is done all in the same operation as removing the axle.
Remember to repack the axle bearing with a good wheel bearing compatable grease as this is the only lubrication it gets. It is not lubricated from the rear end lubricant.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Tool for 8.75 housing seal removal [Re: MoparforLife] #156773
11/25/08 09:37 PM
11/25/08 09:37 PM
if the brake assy wont let you get the just the right angle to catch it & it doesn't for me unless the backing plate & everything is off of there,easiest is to use a piece of allthread as a slide hammer & heat up & bend an L on the other end
Re: Tool for 8.75 housing seal removal [Re: RapidRobert] #156774
11/25/08 10:09 PM
11/25/08 10:09 PM
Upper Midwest
Upper Midwest
Never had a problem even with the brake shoes in place. It doesn't take that much of a pry to release the seal. been doing it this way for years now.
Re: Tool for 8.75 housing seal removal [Re: 68Bullit] #156775
11/25/08 10:22 PM
11/25/08 10:22 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I used a long broom handle. Put the handle in from the opposite side and place it against the back of the seal and hit it will a hammer. Of course the pumpkin was removed.
Re: Tool for 8.75 housing seal removal [Re: VITC_GTX] #156776
11/25/08 10:48 PM
11/25/08 10:48 PM
Yeah I've heard forever that the seals will pop out almost by themselves with the end of the axle to pry them but not for me unless the housing end is stripped. Maybe my skill level isn't as high as I think it is .
Re: Tool for 8.75 housing seal removal [Re: RapidRobert] #156777
11/26/08 02:41 PM
11/26/08 02:41 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
My luck has been 50/50 on getting them out with the axle. There is a seal removal tool that will work. Not one of the pry bars with the like half moon shaped ends. I actually got mine at harbor freight. Small bar with a hook on the end of it to catch the seal. Then a square bar welded at a right angle on the bar. Smack it with a hammer and it will pop right out.
Re: Tool for 8.75 housing seal removal [Re: belv2vert66] #156778
11/26/08 03:02 PM
11/26/08 03:02 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use a cheap slide hammer with the "L" shaped attachment. Due to the depth the seal sits in the axle tube it's difficult to get the new seal in and seated properly without a seal driver imo. So buy extra seals just in case.
Re: Tool for 8.75 housing seal removal [Re: 68Bullit] #156779
11/26/08 03:17 PM
11/26/08 03:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yes there is.
Re: Tool for 8.75 housing seal removal [Re: Lefty] #156780
11/26/08 03:25 PM
11/26/08 03:25 PM
The correct seal driver that has the flat to drive the seal & a shaft to fit the ID of the seal which keeps the spring from being popped loose during install. It's a pricey tool that you wont use too often(I rent it to friends ) but I know the seal wont be damaged & will keep the grease inside where it belongs.
Re: Tool for 8.75 housing seal removal [Re: RapidRobert] #156781
11/26/08 03:44 PM
11/26/08 03:44 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
For those who have never seen one.
Re: Tool for 8.75 housing seal removal [Re: 62maxwgn] #156782
11/26/08 08:56 PM
11/26/08 08:56 PM
Upper Midwest
Upper Midwest
Remember also when you drive the new seal in to drive it in till it hit the solid lip in the housing as a stop.
