Re: a-body exhaust hangers
[Re: 2abodymcodes]
#1567705
01/24/14 01:32 AM
01/24/14 01:32 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
There is a sheet metal plate maybe 0.050" thick with 3 round headed studs spot welded on that goes inside the car. It is held to the floor pan by a sheet metal screw, the reason for the small hole in the center of the 3-hole pattern. The sheet metal plate has two bends to match up to the floor pan.
[Re: kentj340]
#1567706
01/24/14 01:34 AM
01/24/14 01:34 AM
kentj340
Cut and Shoot, TX
Without this, attaching the muffler hanger would be a two-man job.
