a-body exhaust hangers #1567701
01/23/14 07:26 PM
01/23/14 07:26 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
need a picture showing the location of the right exhaust hanger above and in front of the rear axel. (69 barracuda). i need to know where it is located in relation to the seat belt mount.
Re: a-body exhaust hangers [Re: 2abodymcodes] #1567702
01/23/14 09:46 PM
01/23/14 09:46 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Like this 69 Barracuda?
Re: a-body exhaust hangers [Re: kentj340] #1567703
01/23/14 09:48 PM
01/23/14 09:48 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Closer up. If you want dimensions, holler.
Re: a-body exhaust hangers [Re: kentj340] #1567704
01/23/14 11:47 PM
01/23/14 11:47 PM
Shelby, Ohio
2
Shelby, Ohio
perfect. thank you very much.
Re: a-body exhaust hangers [Re: 2abodymcodes] #1567705
01/24/14 01:32 AM
01/24/14 01:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
There is a sheet metal plate maybe 0.050" thick with 3 round headed studs spot welded on that goes inside the car. It is held to the floor pan by a sheet metal screw, the reason for the small hole in the center of the 3-hole pattern. The sheet metal plate has two bends to match up to the floor pan.
Re: a-body exhaust hangers [Re: kentj340] #1567706
01/24/14 01:34 AM
01/24/14 01:34 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Without this, attaching the muffler hanger would be a two-man job.
Re: a-body exhaust hangers [Re: kentj340] #1567707
01/24/14 02:27 AM
01/24/14 02:27 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Heres the one my old 71 Duster 340
Re: a-body exhaust hangers [Re: NV69B7RR] #1567708
01/24/14 09:30 AM
01/24/14 09:30 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
is that painted or coated at all?
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: a-body exhaust hangers [Re: Tommy The Chryco] #1567709
01/24/14 11:49 AM
01/24/14 11:49 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The brackets on my 71 340 Duster were the same, they were added before undercoating/sound deadener was added to the rear wheel wells (as were the fuel and brake hard lines) so depending on the zeal of the undercoating application guy, usually got partial or full coverage. Mine only had a small amount but it was there. They were raw steel prior to that.
