brembo srt calipers swap?
#1567497
01/23/14 01:51 PM
01/23/14 01:51 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
related to the other posts about viper calipers, has anyone tried to use brembo calipers from a jeep srt8 or challenger? Not sure how they attach or thier construction but just an idea for a swap to an older mopar. edit, looks like Mr DR DIFF makes one for a 13" setup. Jeep and challenger use same caliper?
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: brembo srt calipers swap?
[Re: AndyF]
#1567500
02/01/14 02:18 PM
02/01/14 02:18 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Any caliper that uses a radial mount is fairly easy to adapt over to a Mopar disc brake knuckle as long as you are using a 13 inch or larger rotor. Calipers from Porsche, Ferrari, Lambo, Mercedes, etc. are all basically the same. The bolt patterns and the offsets change slightly but generally there is enough room to fit it all together.
The first incarnation of my brakes I used a Challenger SRT, 4 piston Brembo on...then when I was able to round up the pair of 8 piston AMG Brembos they bolted right into place on the same bracket. Was nice and handy.
With the amount of various makes of newer cars coming out with Brembo calipers now from the factory, it gives a bit more selection for donors.
Just make sure your caliper will suit the width and diameter of rotor you pick out of course.
[Re: OzHemi]
#1567502
02/01/14 05:44 PM
02/01/14 05:44 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The drum brake caliper is easy to modify to fit large calipers if you are willing to get the steel cut to make it fit. I use 4140 chomemoly steel that is .400 thick. It maybe heavier but I will never break the adapters. I could use aluminum brackets but I like the added rigidity that the steel offers and I don't have to worry about dissimilar metal corrosion or getting any plating. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: mustardketchup]
#1567506
02/01/14 10:21 PM
02/01/14 10:21 PM
OzHemi
Garden Grove, CA
As well..a lot of the OE setups have their own bracket to mount the other way.. You can see it on one of mine (in the "paint booth" )
