48RE issues AGAIN! #1567013
01/22/14 02:16 PM
01/22/14 02:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I just put 4200 miles on my 04 3500 with the 48RE with a brand new overdrive unit and a rebuilt transfer case. Everything was find until yesterday when I stopped for a train. Put it back in gear, drove through the intersection, then the RPM's went through the roof as if it was in neutral. I coasted to a stop and tried to start again, and the trans slipped. I shut the engine off, waited a few seconds, restarted and put it in gear, and it worked fine for about 500 yards then started doing it again. I was able to get home by stopping, turning off the engine, then restarting and sometimes it would hold for a mile or so then start slipping again. I checked the fluid and it is fine and does not smell burned. I have no idea what is wrong this time. I have not tried it today as I am under the weather which is around zero out anyway.
JB Rhinehart, Realist
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567014
01/22/14 02:24 PM
01/22/14 02:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Last time I had one do that the filter was plugged.
Re: 48RE issues AGAIN! [Re: stumpy] #1567015
01/22/14 02:41 PM
01/22/14 02:41 PM
Rhinotruck
Rhinotruck
I will check that out, thanks!
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567016
01/22/14 08:05 PM
01/22/14 08:05 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Is there any particular gear that it's slipping or any gear?
Re: 48RE issues AGAIN! [Re: redraptor] #1567017
01/22/14 09:45 PM
01/22/14 09:45 PM
Rhinotruck
Rhinotruck
It will only go from first to second as I just drove it again over to the shop and could go no faster than 40 with the tach at 3K! I had to stop several times and shut if off, then restart it to get it going again once it stopped going anywhere.
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567018
01/22/14 10:05 PM
01/22/14 10:05 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sorry to hear of more problems but I am not sure why you have had so many, the 48RE is a very good unit that should not be giving these kind of issues.
To bad I am so far away I have built many of these that my customers have put well over 100k on with no issues.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 48RE issues AGAIN! [Re: dusturbd340W5] #1567019
01/23/14 01:57 AM
01/23/14 01:57 AM
Rhinotruck
Rhinotruck
I was supposed to be in Kissimee today, not happening because of the trans.
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567020
01/23/14 02:48 AM
01/23/14 02:48 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
No personal experience with the 48RE, but plenty with the 47RE. Nearly all of the problems I have experienced have been computer, transducer, or pressure solenoid related. The fact that yours works for a short period after restarting makes me suspicious of your electronics. Are you getting a "check engine" light? if so, pull the codes and see what they say. There is a website: transpartsusa.com that sells 47/48re parts at good prices, ships from FLA. You might check some of the Dodge Cummins forums for specifics on known 48RE failures. Both the 47 and 48RE's are essentially '61 torqueflights with OD, lockup converter, and an electronic governor/oil pressure regulation system. They should have kept the '70s mechanical governor setup, a lot less to go wrong. Oh yeah, make sure the check valve in the trans cooler line is not plugged. Good Luck.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: 48RE issues AGAIN! [Re: 1KoolBee] #1567021
01/23/14 01:23 PM
01/23/14 01:23 PM
Rhinotruck
Rhinotruck
No check engine light and I will check for codes today. I have heard about the check ball, so after pulling the pan and filter I will look into that.
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567022
01/23/14 08:17 PM
01/23/14 08:17 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
if you have the checkball line the best thing is to take it out.transmissioncenter makes a piece to take it out
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567023
01/23/14 08:51 PM
01/23/14 08:51 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I agree with 1KoolBee that it may be solenoid/transducer related. My 47RE burnt the gov sel on my first tow. Wouldn't shift out of 1st even at 5k. Seemed to freewheel after coasting but would jump into 3rd gear if you coasted down a hill fast enough. Lets us know about the checkball thing.
Re: 48RE issues AGAIN! [Re: redraptor] #1567024
01/23/14 11:05 PM
01/23/14 11:05 PM
Rhinotruck
Rhinotruck
Well I changed the filter and it seems fine now. I drove it about 5 miles and it was back to normal. I will drive it more tomorrow and see if it starts to act up again. I am feeling some vibration I haven't felt before, but after 4200 hard miles towing a 24' enclosed with a Firebird then a Chevelle convertible it might just be revolting on me...
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567025
01/24/14 11:23 AM
01/24/14 11:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If changing a filter "fixed" it.... you have alot more problems. Same with the check ball deal. If you are passing enough crap through your filter to plug it.... much deeper issues.
Re: 48RE issues AGAIN! [Re: J_BODY] #1567026
01/24/14 12:52 PM
01/24/14 12:52 PM
Rhinotruck
Rhinotruck
Well I have gone through 3 issues with the overdrive unit that put lots of crap into the system, plus two split trans lines to the cooler which meant at least 30-40 quarts of fluid has been added since all that took place. I found that the trans mount was broken which probably helped split the trans lines. I added the aftermarket transfer case mount this time.
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567027
01/24/14 06:12 PM
01/24/14 06:12 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Were the OD issues related to the plastic bearing separators coming out? I had that happen twice. fixed it by using metal caged bearings and shimming the slop out of the front bearing.
Re: 48RE issues AGAIN! [Re: 1KoolBee] #1567028
01/24/14 09:35 PM
01/24/14 09:35 PM
Rhinotruck
Rhinotruck
No, I had the trans rebuilt and the guy just slapped the original overdrive back on without checking the clearances. The collar (I think it is what is called) was too wide and caused it to be too tight. First issue was the wave ring breaking, so they just put another wave ring in it and slapped back together again. The next issue was basically the same thing then the case ended up cracking a losing fluid. I bought a new assembly from Chrysler and I accidently gave the piston and a few other parts back with the core. Put it back together before I realized it and the overdrive did not work. That is when I called a trans expert I was told to call and he told me what I did wrong and to set-up the overdrive. You have to release pressure on it by removing the wave ring, put a splined shaft in it to align it, then measure a couple different areas and select the proper spacer and collar so it will not beat itself to death. There are several different sized spacers and collars used to set it up correctly. Live and learn, it is only money...
A-Body's RULE!
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567029
01/24/14 09:52 PM
01/24/14 09:52 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Anytime I have had one of my OD trans rebuilt, I always spring for the new OD bearing and seal kit.
So far they haven't let me down.
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567030
01/24/14 10:11 PM
01/24/14 10:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
About time for a new title of trans killer... I never saw someone have so many problems with transmissions in my life!
Anyways maybe run a deep pan without the filter extension and should help keep junk out of the filter til the junk works through.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 48RE issues AGAIN! [Re: Rhinodart] #1567031
01/24/14 10:43 PM
01/24/14 10:43 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
I hear you, the OD is a bit of a PITA to set up. Takes some special tools, but once you've done it, its pretty straight forward. Glad you're back in business. If your wave-ring breaks again, I'd suspect too much play in the front OD bearing. PATC sells a special bearing shim that tightens things up nicely without taking apart the rear planet assembly....and yes, you will have to reset the front piston clearance again....but now that you have done it before, should be pretty easy.
Re: 48RE issues AGAIN! [Re: 1KoolBee] #1567032
01/25/14 09:47 AM
01/25/14 09:47 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you have that much crap floating around in your trans, might be time to install an extra filter. Years ago they used to install a remote oil filter (think motor filter) into the trans line and would spin on a new filter every so many miles.
I'm told it added many miles to the life of a transmission under heavy loads, which is what your doing. I don't know the procedure, but it sounds simple enough. Would be a lot more simple to spin on a new oil filter then dropping the pan a lot of times, especially if you know you have a bunch of junk floating around in there.
They used to add a filter to the cooling system as well.
Gene
