front suspension help #1566788
01/22/14 01:43 AM
01/22/14 01:43 AM
rogersville,mo.
dart340x2 Offline OP
rogersville,mo.
I was told to post over here so I will try again. I have a 74 dart drag car. The problem I am having is when it pulls the front wheels off the ground the front tires go in at the top. I have caltracs on it and they say you need 5" of travel for them to work. It doesn't do it so much if I leave the stops in, but if I take them out it looks bad in pictures. I have seem Mopar with the front up and there tires are staight how can I get this or is it just how it is. Thank
Re: front suspension help [Re: dart340x2] #1566789
01/22/14 03:52 AM
01/22/14 03:52 AM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
With OEM components, you are pretty limited--not much you can do about camber change as the tires drop.
Re: front suspension help [Re: dart340x2] #1566790
01/22/14 07:32 AM
01/22/14 07:32 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Adjustable upper control arms. Or look into the Moog offset control arm bushings, installed right they help you get a nice alignment. I go wheels up nice and straight and the thing could practically drive itself on a good track.
Re: front suspension help [Re: dart340x2] #1566791
01/22/14 09:20 AM
01/22/14 09:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Where is the camber now? Is it positive? Offset upper bushings will help if it's negative? Are the lower control arm bushings worn? Is the K-Frame shimmed down from the rails? The lower arm is longer than the upper. If you have the front end raised the upper is already at a downward angle. Address all these items 1st.
Doug
Re: front suspension help [Re: dvw] #1566792
01/22/14 04:41 PM
01/22/14 04:41 PM
gregsdart Offline
gregsdart  Offline
The upper and lower stock control arms are different lengths to get that camber change. The only way to lessen it is to lengthen the upper control arm or shorten the bottom one, which would lead to a whole lot of issues beyond camber change. If you lengthen the uppers, you have to move the attaching points of the inner ends in the same amount you lengthen the A arm. Your best bet is to limit front travel to about four inch, and make a soft stop if you don't use the factory one. You can also start with the front end lower if there is room.
Re: front suspension help [Re: gregsdart] #1566793
01/22/14 06:47 PM
01/22/14 06:47 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Greg,
What is your suggestion for a soft stop?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: front suspension help [Re: 451Guy] #1566794
01/22/14 07:27 PM
01/22/14 07:27 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Greg,
One thing you can do is replace the stock upper control arm bumper with the larger bumper fron ols style traction bars. Just have to modify the hole that it goes in.
Brian
Re: front suspension help [Re: dart340x2] #1566795
01/23/14 05:56 AM
01/23/14 05:56 AM
If you don't like the pictures don't buy or look at them If you want the tires to not tuck in, limit the front end travel, as you already know that does what you want, correct Does the front tires shake when they hit the ground coming down? Mine would sometimes, but not on others You might want to try stiffening up the front shocks on the extension on the good tracks so it doesn't jerk the front tires up real quickly and continue to go higher One of the Mopar drag race seminar gurus(Leslie I think) use to say if the front tars are off the ground 1/2 inch all the weight is on the rear tars In other words if there going higher your wasting motion and energy picking them up higher than they need to be
Re: front suspension help [Re: dart340x2] #1566796
01/23/14 11:56 AM
01/23/14 11:56 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
If you need to remove the stops to get the 5 inches of travel, that tells me that the ride height is too high.
If you lower the front you can get the camber very close to when the control arm is on the stops as it is at rest.
NMCA NSS 67 Coronet
Re: front suspension help [Re: Barry70GTX] #1566797
01/23/14 12:57 PM
01/23/14 12:57 PM
Pennsylvania
TShell Offline
TShell  Offline
Pennsylvania
