Titanium or Tool Steel Retainers for Street/Strip car? #1566696
01/22/14 12:24 AM
01/22/14 12:24 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am going to run a .750ish lift roller cam and have been doing some research on the supporting hardware. Is there a reason I would run tool steel retainers over titanium on the street? Other reasons I have yet to contemplate?
Thank you for any advice or feedback.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566697
01/22/14 12:34 AM
01/22/14 12:34 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What I can say is that if the springs have a flat-spring damper between the coils, do NOT run ti retainers on the street. The damper will wear a groove into the retainer.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: BradH] #1566698
01/22/14 01:04 AM
01/22/14 01:04 AM
One of my customers in N.Y.(9 seconnd Phil,R.I.P. ) had that happen after 23,000 street and strip miles The inner dampener ate right through the Ti retainer The Ti retainer held the valves in place so he got away with no engine damage Tool steel from then on on any motor that has a inner dampener on the valve springs
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566699
01/22/14 01:07 AM
01/22/14 01:07 AM
AndyF Offline
AndyF  Offline
The new lightweight steel retainers work pretty well and are a lot less expensive than Ti retainers. If you're not spinning it past 7000 rpm then you probably don't need Ti.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Cab_Burge] #1566700
01/22/14 01:11 AM
01/22/14 01:11 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ryan J put tool steel retainers on my heads. It was my understanding that theres no much difference in the weight.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: AndyF] #1566701
01/22/14 01:54 AM
01/22/14 01:54 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Do I hear 7500?
going...
going....
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566702
01/22/14 02:13 AM
01/22/14 02:13 AM
I use to shift the 518 C.I. duster motor at or above 7200 one every run, I did that with both the Ti and tool steel retainers on the Eddy RPM heads No noticeable differences between the two types of retainers
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Cab_Burge] #1566703
01/22/14 02:19 AM
01/22/14 02:19 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Sold at 7500!!!
Thank you Cab!
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566704
01/22/14 03:07 AM
01/22/14 03:07 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
23k miles of street and strip miles.Like everything you have to have maintanence program.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: ksj] #1566705
01/22/14 11:24 AM
01/22/14 11:24 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Which material if I may ask?
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566706
01/22/14 11:38 AM
01/22/14 11:38 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
See Cab's reply.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: ksj] #1566707
01/22/14 12:01 PM
01/22/14 12:01 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm quite happy with my tool steel retainers FWIW
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: Jeremiah] #1566708
01/22/14 01:59 PM
01/22/14 01:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m going on 13+ years with TI retainers and they`re fine and WAY lighter than standard tool steel units. The key is in spring prep and I detail all of the sharp edges on the springs so all the sharp edges are gone............
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: BradH] #1566709
01/22/14 02:50 PM
01/22/14 02:50 PM
BradH Offline
BradH  Offline
FWIW, my ti retainers had maybe 5K worth of street & strip time when I inspected them and found the damage from the dampers. Not sure how prepping the ends of the dampers would have made much difference since they're going to be rubbing up against the underside of the retainer regardless.
I just make it a rule of thumb to not use ti retainers w/ that style of spring as the result, especially because I know I'm not the only person who has experienced this. I've no problems w/ ti retainers on the street w/o flat-spring dampers and will be running new ti parts w/ the PAC springs Dwayne provided me for use w/ my .650" roller cam.
Re: Titanium or Tool Steel Retainers for Street/Strip car? [Re: BradH] #1566710
01/22/14 03:18 PM
01/22/14 03:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As far as "gouging" the retainers, it helps to remove sharp edges and learned that at Pettis years ago. As far as "wear marks" even steel gets em from my experience............
