3-speed wiper motor cycles once and stops? #1566512
01/21/14 03:56 PM
01/21/14 03:56 PM
South Carolina
sixpackbird Offline OP
South Carolina
I have a 1971 Cuda with rallye dash and a 3-speed wiper motor, when the switch is turned on the motor cycles once and then stops, it does not park, stops at the lower end of the wipe cycle. Has anyone experienced this issue?
Re: 3-speed wiper motor cycles once and stops? [Re: sixpackbird] #1566513
01/21/14 05:02 PM
01/21/14 05:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So what do you do when it does that? Does it do it on all three speeds?
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566514
01/22/14 12:11 AM
01/22/14 12:11 AM
South Carolina
South Carolina
When the wipers stop moving I turn the switch off, it appears to do this at all speeds, but I need to confirm this, so far I am turning on to the low speed and this happens.
Re: 3-speed wiper motor cycles once and stops? [Re: sixpackbird] #1566515
01/22/14 12:36 AM
01/22/14 12:36 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The speed of the motor is determined by resistors in the switch. A dry windshield will increase the load and couple that with the reduction of power and maybe even a low battery and voila, you have wipers that stop where they shouldn't.
1) try the switch in all speeds
2) disconnect the linkage and see if its still a problem
Oh, here's something to check ... when the wipers stop, is the motor still turning? If so, the big gear in the transmission has stripped teeth.
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566516
01/22/14 02:43 AM
01/22/14 02:43 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If you turn the switch off does it park? If not how do you get it to return? Did this happen after a motor replacement?
NS1AAR
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566517
01/22/14 06:39 AM
01/22/14 06:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I may be wrong but from what I remember none of the Mopars in the muscle cars years used a switch with resistance in it other then for intermittant wipers. I believe the 2 speed wiper used a resister mounted on the wiper motor for low speed and the 3 speed wiper motors used shunt windings to change the wiper speeds. But to me if yours stops at any place on the windshield it sounds like a motor problem or bad motor ground. If it stops at all different places it does not sound like a park circuit problem which a park circuit could be the switch or motor but that would usually stop in the same place at the bottom of the windshield. Ron
Re: 3-speed wiper motor cycles once and stops? [Re: 383man] #1566518
01/22/14 12:49 PM
01/22/14 12:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmm, you may be right about the switch and shunt windings. There are 4 wires going to the motor so you're probably right. I have a switch out in the shop and I'll look at it later (I'm sure it has resistors on it though).
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566519
01/22/14 03:57 PM
01/22/14 03:57 PM
South Carolina
South Carolina
Thanks for all the input.
The car has been at the body shop for a while, nothing was changed in the IP or the motor. I will be at the shop tomorrow night at will check what happens with all speeds and check the ground to the motor and the switch. When I turn the switch off, the motor does not park, the wipers stay where they stopped at the lower spot on the windshield.
Re: 3-speed wiper motor cycles once and stops? [Re: sixpackbird] #1566520
01/22/14 06:10 PM
01/22/14 06:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If the wipers stop with the switch turned on that would be one issue. If they don't park when the switch is turned off that is a different issue.
A proper ground (that brass ground strap) is very important. The motor does funky stuff without it. I spent HOURS chasing problems all because one of the wires is a "ground" and I figured "a ground is a ground". Not so, one is isolated from the other. You need a good ground to the casting for things to work properly.
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566521
01/22/14 09:52 PM
01/22/14 09:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well I checked my switch and there is only one resistor on it and I think its the "low" speed. If I figure it right, the resistor would go to the lower speed windings of the motor for "low". In the second position it would bypass the resistor and go direct to the low speed windings. In the third position it would go to the high speed windings.
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566522
01/23/14 03:16 PM
01/23/14 03:16 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
theres a test procedure in the fsm for the motor,if you dont have an fsm i think ive heard passonperformance has the procedure on her website.also make sure your instrument panel switch pod has all 4 screws to mount it installed,one is a ground.
Re: 3-speed wiper motor cycles once and stops? [Re: Stanton] #1566523
01/25/14 04:02 AM
01/25/14 04:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You are right as I stand corrected. I looked in my older manuals and the 3 speed wiper system does use a series and shunt winding to control speed but there is one or two resisters in the switch to control how much current goes thru the shunt winding and the motor only has 2 brushes. The more current into the shunt winding the slower the speed and the more current that goes to the series winding the faster the speed. So when a resister is put in series with the shunt winding it lets less current go thru the shunt and more thru the series winding to give a faster speed.
On the 2 speed motor it has a resister on the motor housing and it has 1 ground and 2 speed brushes. It changes brushes from high to low and has the resister in the low speed brush circuit as a current limiting resister. Ron
Re: 3-speed wiper motor cycles once and stops? [Re: 383man] #1566524
01/25/14 08:29 PM
01/25/14 08:29 PM
O
OLD318 Offline
OLD318  Offline
O
FWIW... I don't want to start a holy war here
and yes you can call me ignorant...
I'm just stating my opinion based on years of dorking with
these things..
If nobody else agrees that's cool....
But I think the 3 speed wiper motors on these cars suck....period.
Even brand new/rebuilt working perfectly, brand new switch blah blah
blah, they are lame by today's standards...
I understand this is all due to the design of that time period which is voltage through the switch...
I've never dealt with a 2 speed so I can't comment on those.
I've dealt with A-body B-body and C-body 3 speed motors,
and none of them are anything to write home about..
They are barely adequate AFAIC...
The park mechanism is easily broken.
It doesn't matter if you have an alternator upgrade or
any other electrical upgrades (MAD electrical upgrades etc.)
There is nothing that I've seen or heard about that improves the wiper motor performance to match today's cars..
Again, this is by design (all the voltage through the switch with resistors in the switch etc...)
True, they work...but I'd take the wiper system of my 2000 Buick century or my 2003 F-150 in a heartbeat if there was a retrofit kit
available...
anyway...just my 2cents...
