Mild Comp SB roller...
#1566293
01/21/14 04:05 AM
01/21/14 04:05 AM
Posts: 1,730 Red Deer, Alberta
bill_greenwood
Red Deer, Alberta
I think I've landed on a cam pick to replace my wounded MP528 solid. Given that I already have lots of gear and convertor, the Comp 20-702-9 R308 grind looks quite compatible with the rest of my package. 575 lift, I & E, 262 dur at .050, 110 deg lobe centers. I don't think my heads will support much more than that lift wise, and it seems as though I need a bump in duration as much as anything. Has anyone here ran that stick in a 340 or 360? I'm leaving at a good 4500 convertor flash, shifting at 6800, and hitting the lights at 7100, so I might as well get a cam that will work better from 4500-7000 than my current.
Re: Mild Comp SB roller...
[Re: bill_greenwood]
#1566294
01/21/14 04:12 AM
01/21/14 04:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Without knowing what the heads flow or what they are I would think more lift.... if you go to the max flow on the lift, you only see that point once... BUT if you go above the max flow lift point you see that max flow 2 times... I know it helped mine... I'm planning on going larger yet
[Re: MR_P_BODY]
#1566295
01/21/14 06:35 AM
01/21/14 06:35 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I have run that cam in another engine. It's a street roller with pretty mild ramps. I think it made better low end tq than the MP 296/.557" cam but was a bit down on power, as strange as it may seem.
Plynouth VIP '67 TT IC EFI
[Re: MR_P_BODY]
#1566298
01/21/14 01:54 PM
01/21/14 01:54 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
THIS..........been saying this and using this theory for years about getting a cam with more lift than the heads peak at and more duration and my junk has always been quicker than most at similar weight and engine size.
[Re: mopar dave]
#1566299
01/21/14 01:54 PM
01/21/14 01:54 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
11.7:1 static, The cam I got now is a similar .050 duration but it was designed for the Dodge IROC motors so it's really (and I mean REALLY) broad torque but the lobes are obviously more endurance oriented (only .585/.570 lift @ 1.5) to save the springs....It is very rev happy, but just not suited to the airwolfs higher lift/higher flow capacity. Whichever motor the bullet winds up in the other one is getting this cam since it'll be a perfect street/strip roller. If this one stays in the 414 I think I'll go to 1.6's since I know the motor will like the extra lift. Don't mean to jack the thread buddy! As for the "over the nose" theory it still applies but but it's a lot less critical when dealing with a Roller, Definately applies to a flat tap since there's no effective Dwell over the nose, you need more on a FT to try to emulate the roller's ability to 'park' the valve for several degrees. Getting a roller "perfect" has as much to do with the Flanks (ramp area under the curve for the flow window)...maybe more, (especially with wedge heads) as it does with the "square" part of the lobe.
#1566300
01/21/14 02:15 PM
01/21/14 02:15 PM
Quicktree
i run that cam in my 360 and love it for what it is. easy on springs makes good power
[Re: Quicktree]
#1566302
01/21/14 04:38 PM
01/21/14 04:38 PM
Posts: 1,178 Indy
FlyFish
Indy
Just curious, what kind of times are you getting with that cam? I thought about trying it out a few years back, but never did. I still have a XR286R from Comp in my 410 stroker (and quite happy with it for what it is).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: MR_P_BODY]
#1566303
01/21/14 07:28 PM
01/21/14 07:28 PM
Posts: 617 PA
bwhackd34
PA
I have always been a proponent of this theory myself!!!
[Re: FlyFish]
#1566304
01/21/14 08:13 PM
01/21/14 08:13 PM
Quicktree
we ran 10.40 @ 129 in my challenger stock crank 360 with indy heads
[Re: Quicktree]
#1566306
01/23/14 02:12 PM
01/23/14 02:12 PM
Thumperdart
State of confusion
Ya, at 2800 lbs...............details baby...............
[Re: Thumperdart]
#1566307
01/23/14 02:37 PM
01/23/14 02:37 PM
Quicktree
3050lbs there thumper dude. back half with steam roller 16x32s. basic 727 no trans brake stock 360 block stock crank eagle rods with probe 11.5/1 compression. what other details would you like there sport?
[Re: Quicktree]
#1566308
01/23/14 02:47 PM
01/23/14 02:47 PM
Thumperdart
State of confusion
You old guys really know how to get the most from your stuff fo sho..............
[Re: Thumperdart]
#1566309
01/23/14 07:24 PM
01/23/14 07:24 PM
Quicktree
it's all in the heads, with out the monster tires and a little more converter it would go 10.20s easy
