Wheelie Bar setup #1565510
01/19/14 04:31 PM
01/19/14 04:31 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
We're in the process of fab'ing up a set of wheelie bars and need to know where to set the wheels initially...
I've noticed that once the bars are in place, we'll have approx. 2" of adjustment, but where should we start at?
The car is a 3000lb Duster, ladder bar, big tire car which has a 1.2x 60' and 151 mph.
One set of instructions says 3.5" - 4" off the ground, however a veteran racer says his are set at 6+"... So any advice given is appreciated..
Re: Wheelie Bar setup [Re: Jeepmon] #1565511
01/19/14 04:48 PM
01/19/14 04:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being a ladder bar car I would set the mid travel
at about 4"..ladder bar cars tend to rotate a fair
bit.. also are you talking the bottom of the wheel or
the center line of the axle
EDIT
Also what style is it... with the springs or solid
but I was referring to the bottom of the wheel...
but When I set them at the track I measure to the axle
Re: Wheelie Bar setup [Re: MR_P_BODY] #1565512
01/19/14 04:54 PM
01/19/14 04:54 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I'll set it for what ever it needs to be, as I have zero experience and this is my first time dealing with wheelie bars..
I'm pretty sure we have it tacked into place at 5" right now, measured at center of wheel and the adjusters are also centered..
Re: Wheelie Bar setup [Re: Jeepmon] #1565513
01/19/14 05:08 PM
01/19/14 05:08 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Set em up just like this.lol I have a personal question...How long is your wheelie bar? lol
http://youtu.be/rjDy72oOwoc
Re: Wheelie Bar setup [Re: Jeepmon] #1565514
01/19/14 06:24 PM
01/19/14 06:24 PM
gregsdart Online content
gregsdart  Online Content
When and where do you plan to test? If I am close, it would be fun to come watch.
Re: Wheelie Bar setup [Re: WheelsUp73] #1565515
01/19/14 06:26 PM
01/19/14 06:26 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
3.5 to 4 inches to the bottom of the wheelie wheel on the junk I mess with.
Re: Wheelie Bar setup [Re: FastmOp] #1565516
01/19/14 06:56 PM
01/19/14 06:56 PM
I have mine (66 inch long, ladderbars) about 6 inch up. Left side wanted to be 1/4 inch higher. It is important to make sure the wheeliebars aren't steering the car ,compensating for the wrong suspension adjustments. I have an anti roll.
Re: Wheelie Bar setup [Re: gregsdart] #1565517
01/20/14 01:07 AM
01/20/14 01:07 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thank you all for your advice.. The bars are 60" long and we ended up getting them at 6" off the ground, at the center of the wheel.
We also lifted the front end of the car to simulate the max height we want on the launch and it appears as the 6" is pretty darn close.. So if my shoulder heals up a little during this next week, we'll be testing at Sonoma next Sunday..
Thanks again everyone
Re: Wheelie Bar setup [Re: Jeepmon] #1565518
01/20/14 01:46 AM
01/20/14 01:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lifting the front while is sounds cool really don't get ya close. Mainly due to the rear separation. Remember first move the suspension will make will be to slam those bars into the ground. Especially on a ladder bar car with those shocks. As I said a ladder bar will separate a good deal so I would start with a higher number initially. If you need to you can always go shorter later but in my experience you will be fine with them at 6 to start.
Re: Wheelie Bar setup [Re: Al_Alguire] #1565519
01/20/14 02:11 AM
01/20/14 02:11 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
This is at about 4"...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Wheelie Bar setup [Re: Eric] #1565520
01/20/14 02:13 AM
01/20/14 02:13 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Is that a Ladder bar set up???
Re: Wheelie Bar setup [Re: Al_Alguire] #1565521
01/20/14 02:13 AM
01/20/14 02:13 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I can move the bars to the top hole and that gives about 10" clearance
Re: Wheelie Bar setup [Re: Jeepmon] #1565522
01/20/14 02:15 AM
01/20/14 02:15 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
4-link
Re: Wheelie Bar setup [Re: Eric] #1565523
01/20/14 02:16 AM
01/20/14 02:16 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Eric
Re: Wheelie Bar setup [Re: Jeepmon] #1565524
01/20/14 01:32 PM
01/20/14 01:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With that length of bar the front end travel will help determine the height, we would suggest setting the adjustment in it's center travel and set the bars 4 to 6 inches from the bottom of the wheel to the ground.You can always modify the adjusters for additional adjustment.This is for spring loaded bars,solid bars should be set at aprox.4 inches or less. Final adjustment needs to be done at the track.
Re: Wheelie Bar setup [Re: B G Racing] #1565525
01/20/14 02:27 PM
01/20/14 02:27 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Bob... The one thing I forgot to add is its solid bars... no springs..
Re: Wheelie Bar setup [Re: Jeepmon] #1565526
01/20/14 02:49 PM
01/20/14 02:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Solid bars should be set at or before full front suspension travel.If they are set too high and hit real hard they may unload the rear tires.We like the spring loaded bars on a backhalved stock front suspension car or a short wheelbase chassis car.If you like big wheelstands use the sprung bars and they soften the hit and allow you to "hang em high" with out unloading the slicks.
Re: Wheelie Bar setup [Re: B G Racing] #1565527
01/20/14 03:03 PM
01/20/14 03:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Short(60")sprung bar at 4" and 4.5"
Long(74")solid bar at 6 and 6.5
Re: Wheelie Bar setup [Re: Jeepmon] #1565528
01/20/14 04:20 PM
01/20/14 04:20 PM
Sounds like you have the Duster working rather well.
Seems you think you may have a problem, otherwise you wouldn't have gone to the trouble of putting on the bars.
What do you want the bars to do?
Limit the front rise?
Safety device?
Remember if the bars are too low and hit the solid wheeliebars hard you can unload the rear tires.
Re: Wheelie Bar setup [Re: ] #1565529
01/20/14 04:37 PM
01/20/14 04:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
When I added bars to mine several years ago, I added them for one reason,,,,,"just in case",, I was told by several chassis people to never put them on to use them as a tuning aid, I have since had the chassis tuned in to work, not to impress the crowd,(not saying you are) but in the beginning I was glad they were there as I think they saved me some repair on my front suspension just to add to this post mine are set at 4" from the bottom of the wheel to the surface, and by being there the car lifts just enough to skim the shoe polish off of them.
