e body 383 with A/C heater hose routing and size? #1565495
01/19/14 03:29 PM
01/19/14 03:29 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
I am rebuilding my 383 in my 1970 challenger vert with A/C. The previous owner used a lot of aftermarket parts in the restoration.
I am trying to get things somewhat straight.
The aftermarket water pump housing has two 5/8 inch heater hose connectors. I know one should be 1/2 inch. I have the conversion for the 5/8 hole to a 1/2 inch.
1. Which hole gets the 1/2 inch connector on the water pump housing?
2. what size hoses go to the water bypass valve and to the heater core?
3. What is the true routing of the heater hoses?
Thanks,
Smos
Re: e body 383 with A/C heater hose routing and size? [Re: smos001] #1565496
01/19/14 04:25 PM
01/19/14 04:25 PM
I ain't sure if they are 2 different sizes as my BB experience is limited (but I do have a 451 (slowly) coming together ) but the (BB) pump housing nipple higher up on top is the hot water coming out from the eng (which obviously will go to the heater inlet) & the forward (lower) nipple on the pump housing is the pump inlet (coming out from the heater). EDIT if the pump has a 5/8 and a 1/2 nipple(s) then the 5/8 one is the hot coolant out from the eng to the heater inlet & that'd be the one on top rearmost on the housing
Re: e body 383 with A/C heater hose routing and size? [Re: RapidRobert] #1565497
01/19/14 04:46 PM
01/19/14 04:46 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The 1/2" (rear) is hot coolant out, the 5/8" (front) is return.
Re: e body 383 with A/C heater hose routing and size? [Re: John_Kunkel] #1565498
01/19/14 04:50 PM
01/19/14 04:50 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
I found a hard to read diagram for basic routing and I think it confirms that the front (5/8, now) is out of the water pump and the rear toward the firewall 1/2 now) is in to the water pump.
Anybody have a bypass valve? does it have 1/2 inch connection on both sides? Does the heater core also have a 1/2 inch connection?
Re: e body 383 with A/C heater hose routing and size? [Re: John_Kunkel] #1565499
01/19/14 04:54 PM
01/19/14 04:54 PM
I'm backwards on that john?
Re: e body 383 with A/C heater hose routing and size? [Re: RapidRobert] #1565500
01/19/14 04:59 PM
01/19/14 04:59 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
so there is a 1/2 inch connector on the rear of the water pump housing towards the firewall? The 5/8th inch is towards the radiator?
Re: e body 383 with A/C heater hose routing and size? [Re: smos001] #1565501
01/20/14 12:05 AM
01/20/14 12:05 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's where the confusion starts... And probably why you're ..The A/C water valve has {1} 1/2 inch connection and {3} 5/8 connections...5/8 from engine to valve...5/8 to and from the heater core to the valve...Then 1/2 inch from valve to engine..
Re: e body 383 with A/C heater hose routing and size? [Re: screamindriver] #1565502
01/20/14 12:30 AM
01/20/14 12:30 AM
Harrisburg, Pa.
Harrisburg, Pa.
Don't mind all the aftermarket goodies..The valve placement and hose routing is correct...The label was to show where a large black strap{marked clip} would be in a factory application...If I remember correctly the hoses would be routed through the large black strap to hold them{could'nt be done in this case}...You can make out the 1/2 inch and 5/8 script on the Mopar hoses..
Another point to make would be the hose shield bracket that would be present on a big block...it fastens to the alt.bracket and keeps the hose from contacting the belts...You can see it in this pic...
Re: e body 383 with A/C heater hose routing and size? [Re: screamindriver] #1565503
01/20/14 12:24 PM
01/20/14 12:24 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
Thanks!
Much appreciated. Now it all makes sense.
Looks like a beautiful setup you have under the hood.
Re: e body 383 with A/C heater hose routing and size? [Re: smos001] #1565504
01/20/14 03:20 PM
01/20/14 03:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, if the diagram was clearer you would see arrows in the hoses...the arrow in the rear (1/2") hose is pointing out, front pointing in (towards pump).
Re: e body 383 with A/C heater hose routing and size? [Re: John_Kunkel] #1565505
01/20/14 04:02 PM
01/20/14 04:02 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
Thanks,
makes sense now.
The 1/2 inch connector is on rear of the water pump housing and it eventually connects to the 1/2 inch connector on the bypass valve.
Which then routes from the bypass valve and connects to the left (passenger side), left facing the firewall)? connector at the firewall. (I have a left and right connection on the firewall for the heater core). All though I am not 100 percent sure on that part of the equation to the firewall.
thanks,
Smos
Re: e body 383 with A/C heater hose routing and size? [Re: smos001] #1565506
01/20/14 08:15 PM
01/20/14 08:15 PM
Harrisburg, Pa.
Harrisburg, Pa.
Thanks!
Thanks...I tried to clean up the busy engine compartment on this one and kept the A/C hose routing on the right...It's harder to customize than it is to follow the beaten path.. Do you have the 70 challenger FSM ??? Here's a link for the download if you need it.. 70 Dodge challenger FSM
Re: e body 383 with A/C heater hose routing and size? [Re: screamindriver] #1565507
01/20/14 09:42 PM
01/20/14 09:42 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
WOW!!!!
very cool.
I do have that link. Great site.
Do the heater hoses cross or do they stay even from the bypass valve to the firewall? I can't see the heater hoses behind the back of the engine.
Re: e body 383 with A/C heater hose routing and size? [Re: smos001] #1565508
01/21/14 12:08 AM
01/21/14 12:08 AM
Harrisburg, Pa.
Harrisburg, Pa.
Here's the pic you've been waiting for click on the attachment.. Note the direction of flow...The short answer is the hoses do NOT cross over each other...In the case of the E body coolant enters the left tube, cascades through the heater core then exits the right{passenger}tube...heading to the water valve then back to the engine...
Re: e body 383 with A/C heater hose routing and size? [Re: screamindriver] #1565509
01/21/14 12:13 AM
01/21/14 12:13 AM
usa
smos001 Offline OP
smos001  Offline OP
usa
Perfect!
Thanks,
