Re: Mildew removal from seats and door panels
[Re: 72CUDA340]
#1565265
01/19/14 01:21 AM
01/19/14 01:21 AM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
SoftScrub with bleach. You may want to dilute it until you see how your panels like it.
Master, again and still
[Re: 72CUDA340]
#1565267
01/19/14 02:19 PM
01/19/14 02:19 PM
Posts: 120 CT,USA
72CUDA340
CT,USA
Thanks for the advice guys.Going to give lysol a shot since I have some already. Do you use lysol disinfectant or the mold&mildew stuff with bleach?
[Re: 72CUDA340]
#1565268
01/19/14 02:34 PM
01/19/14 02:34 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Here's the problem ...
Mold and mildew form wherever there is moisture. So it is on the back of every panel, behind the dash, on the wiring, under the headliner, under the carpet, inside the seats, etc, etc.. So when you tackle it, take as much apart as you can. Any mold you miss will spread if conditions are right. If the car smells of mold and mildew, its there! Once you've cleaned it to your satisfaction, you'll need to keep the car moisture-free while in storage so you should invest in a de-humidifier for your shop. The worst thing is humid summer weather.
Also, if its been there a while the mold and mildew is going to leave a very distinct stain that is impossible to wash away. Armorall or a similar product will mask it.
Good luck !!
