Re: Gasket Qustion
[Re: moparpiff]
#1564996
01/18/14 01:00 PM
01/18/14 01:00 PM
Posts: 596 Mass.
80fbody
Mass.
Deleted.
Re: Gasket Qustion
[Re: moparpiff]
#1564997
01/18/14 03:00 PM
01/18/14 03:00 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Does anyone have a part number for the gasket that goes in between the oil filter plate and the block for a 360 LA? I can't seem to find one anywhere and need one.
Come on you guys saying you don't need it, read the post first before misleading him You can not run the oil filter adapter plate on the side of the block without the gasket, you all know that OP, contact your local Dodge or Chrysler dealer if you can't buy it anywhere else That is with the screw on adapter, not the 90 degree adapter If your using the 90 degree adapter you will need the cork inner gasket also, maybe even with the steel adapter screw on plate also, make sure and verify what you really need
Re: Gasket Qustion
[Re: moparpiff]
#1564998
01/18/14 03:12 PM
01/18/14 03:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If its the one I'm thinking of(between the filter plate and block) its needed... will pour oil out if not used...I got a few and I think I got one from Performace gasket(I think thats Gregs place)
Re: Gasket Qustion
[Re: moparpiff]
#1565000
01/18/14 04:11 PM
01/18/14 04:11 PM
MR_P_BODY
Yes it is for the the screw in plate without an adapter. I know that I need it otherwise you will successfully empty the oil all over the place and make a huge mess. I have seen it happen. I know they come in the engine gasket kits but I wanted the part number if I ever needed it by itself. Thanks to all for their input.
I'm sure I got one set from Greg(Superformce Gasket) but I dont have the package around to get the number.. all it was, was the big(maybe 5" dia) and the small 3/4" for the stud on the center that the filter mounts on.... I know I talked to Greg on this because I asked about the thickness of the large gasket... I was having issues with the outer gasket sealing with the plate I had... it was either grind down the center area where the center stud goes in or double up the large gaskets... I think some where over the years the step in the plate changed and the one I had didnt have enough to seal the outer OD with just one gasket.... I ended up glueing the 2 gaskets together due to the engine was already in the car... if it wasnt in I would have milled the center area down some
Re: Gasket Qustion
[Re: Cab_Burge]
#1565001
01/19/14 12:32 PM
01/19/14 12:32 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Sorry for taking this in the wrong direction. Need my eyes checked and should not be speed reading I will have the oil plate gaskets available soon
Re: Gasket Qustion
[Re: roadhazard]
#1565002
01/19/14 12:39 PM
01/19/14 12:39 PM
MR_P_BODY
Sorry Greg... I thought it was you I got them from.. but your gonna have it soon so it wasnt you I talked to about them..... I cant remember who I talked to. I might have gotten them from Mancini's
Re: Gasket Qustion
[Re: MR_P_BODY]
#1565003
01/19/14 01:18 PM
01/19/14 01:18 PM
roadhazard
Akron, Ohio U.S.A.
Mike, not to take this thread OT. I did in fact check the 90* oil filter adapter gasket in a factory block and it fit perfect. The bore on the block measured 4.640" and the gasket is 4.645" O.D. to hold it in there in case your on your back during the install
I assume your block was machined undersize if you had problems with the install
