Small block belt drive/front drive distributor #1564970
01/18/14 11:15 AM
01/18/14 11:15 AM
PA
bwhackd34 Offline OP
PA
I have a tall deck belt drive and front drive distributor setup laying around. My plan was to use them on a 468" Indy 360-1 245cnc dual 1050 on E85 setup with an external single stage oil pump. As I feel it is a going to be a while until I finish acquiring all the parts and doing all the work(only have block, heads, crank, pistons, intake and carbs right now) I am contemplating putting it on my w2 352 in my Duster with a remote water pump reverse cool setup. My question is being the 352 is an internal oil setup and I want to use the front drive distributor am I going to need to fab up a oil pump drive hold down from an old distributor to keep the gear from lifting out of the pump? I made up a cap for the existing hole but was wondering about this....any one using a similar setup with any experience?
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564971
01/18/14 11:43 AM
01/18/14 11:43 AM
PA
PA
pic
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564972
01/18/14 01:02 PM
01/18/14 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you will need to fab something to hold the drive
down in the pump... something simple will work
Re: Small block belt drive/front drive distributor [Re: MR_P_BODY] #1564973
01/18/14 01:04 PM
01/18/14 01:04 PM
PA
PA
I actually expected a response from you...lol Any ideas....does it need to be fabed from a distributor or do you have another suggestion?....
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564974
01/18/14 01:12 PM
01/18/14 01:12 PM
PA
PA
I am thinking of buying one of the cheapo (45) billet distributors from Ebay and cutting it in half...then using my 1/4 disc to cover the center hole......
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564975
01/18/14 01:22 PM
01/18/14 01:22 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I think Andy has something for this.
Re: Small block belt drive/front drive distributor [Re: MattW] #1564976
01/18/14 01:34 PM
01/18/14 01:34 PM
PA
PA
I am sorry I do not know who Andy is....do you have a link or contact info?....
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564977
01/18/14 01:40 PM
01/18/14 01:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I fabbed up a piece for a guy to do the same thing..
I spun up a plate to fit the dist hole and welded a
1/2" rod to it the proper length
Re: Small block belt drive/front drive distributor [Re: MR_P_BODY] #1564978
01/18/14 01:54 PM
01/18/14 01:54 PM
PA
PA
I thought of something this simple but was concerned with wear at the contact point of the rod and gear creating unwanted debris in the engine....that is why I thought of cutting a distributor so I could utilize the shaft....the collar would keep the shaft from pushing out and my disc would seal the top to keep outside debris from getting in.
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564979
01/18/14 01:59 PM
01/18/14 01:59 PM
AndyF Offline
AndyF  Offline
Big block version
Re: Small block belt drive/front drive distributor [Re: AndyF] #1564980
01/18/14 02:02 PM
01/18/14 02:02 PM
PA
PA
Do you make for the small block?
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564981
01/18/14 08:53 PM
01/18/14 08:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I cut the head off a stock dizzy , cut the shaft to length and made a Delrin plug ( like nylon ) for the top.
15.00 and about 1/2 hour of work.
Re: Small block belt drive/front drive distributor [Re: tubtar] #1564982
01/19/14 09:57 AM
01/19/14 09:57 AM
PA
PA
awesome..probably the way I will go too!
Re: Small block belt drive/front drive distributor [Re: bwhackd34] #1564983
01/19/14 01:08 PM
01/19/14 01:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I leave a .010 gap between the gear and the hold down..
the gear is trying to pull downward on accel and tries
to lift on zero load or decell.. the only time the
rod comes in contact is zero load or decell... if you
want you can put a hard plate on top of the gear like
a torrington bearing but I never felt it was needed
