So how did this happen?
#1564911
01/18/14 12:33 AM
01/18/14 12:33 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
A couple of days ago I was preparing the car for the new season and discovered what I thought was a single crack in the block on the passenger side which runs from the top of the front freeze plug to beyond the top of the back freeze plug. Today while pulling the motor I discovered that the driver side is also cracked in the same place. Whoa!!!!! I consider myself lucky as the car was running fine last time out, and to think about what could have happened just sends chills down my spine. Details: 500 Wedge all motor, 625 HP, 727, No trans brake, motor plate with straps from the frame to the motor mount bosses on both sides. Any thoughts so I don't have the same thing happen again, if by chance I did something wrong that I don't know about. Thanks ole wise ones......
Re: So how did this happen?
[Re: bigdad]
#1564913
01/18/14 12:50 AM
01/18/14 12:50 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Did you have ani freeze and did it get cold enough ?
I am in California and the car is kept in a 72 degree temp controlled shop.....
[Re: Dart Racer]
#1564914
01/18/14 01:01 AM
01/18/14 01:01 AM
Don't know your setup, but torque straps to one of the mounting bosses is never a good idea.......
I don't get why the passenger side would be cracked also though....unless....do you have rigid straps on both sides ??
[Re: Dart Racer]
#1564915
01/18/14 01:02 AM
01/18/14 01:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you have engine limiters on both sides(to each mount) and does the crack start near the mount ears
[Re: MR_P_BODY]
#1564918
01/18/14 03:01 AM
01/18/14 03:01 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
[quote Do you have engine limiters on both sides(to each mount) and does the crack start near the mount ears
Yes, engine limiters on both sides and attach to the motor mount attachment points. Crack starts right at top of freeze plug and runs horizontally past the rear freeze plug.
[Re: 80fbody]
#1564919
01/18/14 03:03 AM
01/18/14 03:03 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Is this a filled block?
Yes, filled to the bottom of the freeze plugs
[Re: ]
#1564921
01/18/14 03:06 AM
01/18/14 03:06 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Yes strap to each motor mount boss.
[Re: ]
#1564922
01/18/14 03:11 AM
01/18/14 03:11 AM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Where should they be attached? I never considered the motor mount boss wouldn't work given that's what point the factory used to hold the engine.
[Re: Dart Racer]
#1564923
01/18/14 03:26 AM
01/18/14 03:26 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Had a 66 block that did the same thing. Rubber mounts, only 540 hp.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Dart Racer]
#1564924
01/18/14 03:46 AM
01/18/14 03:46 AM
MR_P_BODY
The original mounts were rubber so it didnt slam anything... I dont know the relationship between the freeze plug holes and the mount ears on a big block but if the ears are near the crank and a weak block then MAYBE thats your problem... I have limiters on both sides on my SB to the mount ears and havent hurt any block... a pic would really help
[Re: Oyvind Mopar]
#1564928
01/18/14 10:49 AM
01/18/14 10:49 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
My 65 casting 440 block cracked between the soft plugs also.It was in for 30 years.Never dripped and never froze.At the machine shop they found the crack.Now I run my 70 block.It ran on OE mounts and wasnt making a ton of HP.Rocky
Chrysler Firepower
[Re: Dart Racer]
#1564930
01/18/14 11:34 AM
01/18/14 11:34 AM
The original mounts were bolted to 3 points on each side....if u have rigid straps going to only one of the bosses.....that's where the problem lies imho
