Keith Black piston part numbe help please #1564621
01/17/14 06:54 PM
01/17/14 06:54 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Have a set of new pistons on the shelf that I can't identify the part number is KB 825 which doesn't pull anything up any of you guys know what they are I know they are a big block Mopar I think they go to a 470 but not sure??
Re: Keith Black piston part numbe help please [Re: DaKuda] #1564622
01/17/14 06:59 PM
01/17/14 06:59 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Do they look like any of these under the Icon series?
http://www.cnc-motorsports.com/catalogsearch/result/?q=Ic+825
Re: Keith Black piston part numbe help please [Re: BradH] #1564623
01/17/14 07:08 PM
01/17/14 07:08 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Yes they look similar to those what threw me off is it says they have an over bore of .033??
Re: Keith Black piston part numbe help please [Re: DaKuda] #1564624
01/17/14 07:12 PM
01/17/14 07:12 PM
BradH Offline
BradH  Offline
Low-block pistons: OEM 400 standard bore of 4.342" + .033" = 4.375", rather than OEM 440 standard bore of 4.320 + .055" to get to same 4.375".
Re: Keith Black piston part numbe help please [Re: DaKuda] #1564625
01/17/14 07:13 PM
01/17/14 07:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Jeep 4.0 inline 6, used in stroker motors a lot. I use H802cp's and the 825 should be h825CP. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Keith Black piston part numbe help please [Re: BradH] #1564626
01/17/14 07:24 PM
01/17/14 07:24 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
so is that a common piston size for a 470?
Re: Keith Black piston part numbe help please [Re: DaKuda] #1564627
01/17/14 08:42 PM
01/17/14 08:42 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
First thing first, The KB number is now a IC number no change in the piston.
Second the most comon 470 is the low deck (400) 4.342 + .033 =4.3752" bore x 3.900" stroke. The actually size is 469CID.
Go here:
https://www.uempistons.com/index.php?mai...31e2c4e580ad271
Re: Keith Black piston part numbe help please [Re: Biginchmopar] #1564628
01/17/14 08:58 PM
01/17/14 08:58 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
thanks guys
