528 hemi 1/4 mile times
#1564477
01/17/14 01:51 AM
01/17/14 01:51 AM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Does anybody have times for their 528 hemis and what the combos are? I have Ray Barton all aluminum 528 that I just put in my cuda and am trying to get a idea of the average times that people are getting with them.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 528 hemi 1/4 mile times
[Re: Dragula]
#1564486
01/17/14 01:39 PM
01/17/14 01:39 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I've run 9.17 @ 147mph with a 528 Hemi in a 3,200 lb. A-body.
Street tires and mufflers too if I remember right...
Don't forget the supercharger.
[Re: 73cuda340]
#1564487
01/17/14 02:48 PM
01/17/14 02:48 PM
Triple Threat
Renton Washington
The OP's car is clearly a street toy and is not prepped for real race duty. Bolting on some sticky tires and adding cal tracs aren't gonna be enough to hook that thing.
As stated, with those power numbers, you should have no problem running well below the 11.49 cut off, which will lead to you being booted from the track for no rollbar, no harnesses etc.
A 700 HP hemi in a good drag car, will run well into the 9's @ 140mph+
[Re: Triple Threat]
#1564489
01/17/14 03:14 PM
01/17/14 03:14 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
Maybe in a light A Body but in a heavy (3700) E body 700 hp only gets you into the low 10's
