Re: Sandblast manifolds before or after machine work?
[Re: parksr5]
#1564436
01/17/14 01:43 AM
01/17/14 01:43 AM
Personally, I would blast and then mill/planed. However, if you chose to do it the other way, sand blasting shouldn't hurt it.
[Re: ]
#1564437
01/17/14 02:14 AM
01/17/14 02:14 AM
Posts: 889 Oh
parksr5
Oh
I didn't think it would but I thought I'd get some opinions before doing anything. Thanks!
[Re: parksr5]
#1564438
01/17/14 06:51 AM
01/17/14 06:51 AM
Posts: 75,028 U.S.S.A.
JohnRR
U.S.S.A.
If you sandblat them after DO NOT sandblast the machined surfaces.
I would have them shotblasted first , then machined , sandblast if needed .
[Re: parksr5]
#1564440
02/07/14 09:34 PM
02/07/14 09:34 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I would say it doesn't matter either way, you can always put duct tape or masking tape on the machine surface to protect it from the blaster.
I've etched glass in a sand blaster using masking tape as the pattern template. Blaster didnt touch the masking tape.
**Photobucket sucks**
