Hidden Radio Setups? #1564044
01/16/14 05:08 PM
01/16/14 05:08 PM
PA
RoadRunner73 Offline OP
PA
Finishing up my dash and wiring in my 73 Bird and I am looking for a good way to have my old radio installed to keep the classic look but be able to play music from my phone. Anyone have a good setup? I dont want to put a cd changer or anything like that in my trunk and I dont want to spend a fortune on sending my old radio to be restored or brought up to date with modern insides...
1973 Plymouth Road Runner
Re: Hidden Radio Setups? [Re: RoadRunner73] #1564045
01/16/14 05:42 PM
01/16/14 05:42 PM
Vancouver,WA
70b5bird Offline
70b5bird  Offline
Vancouver,WA
try this site http://www.casmfg.com/Secretaudio.htm
i put one in my 70rr. all hidden, sounds great.
Re: Hidden Radio Setups? [Re: 70b5bird] #1564046
01/17/14 12:52 AM
01/17/14 12:52 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
My brother and I installed a new style radio in the glove box of my dad's 67 Fairlane.
Re: Hidden Radio Setups? [Re: RoadRunner73] #1564047
01/17/14 01:56 AM
01/17/14 01:56 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I am using a Kenwood KDC855HD mounted in the trunk. I used a splitter on the AM antenna to feed it. I ran USB extension under the carpet to next to the console. Along side, I ran a shielded speaker connection so I can use an Ipod or a Zune. I also use Bluetooth from my Android Bionic. I used a Radio Shack IR repeater with the receiver on the console so I can remote control everything with the Kenwood remote. The only thing I cannot control is the music tone settings. Unfortunately, I have to tweak those from the trunk but once I have it the way I want it, it remembers it.
In actual operation, the USB connection using a stick with all the music on it does not work as well as I hoped. Using either the Android or Zune is the easiest on controlling the playlists. The USB works as a power supply for the Android however. I have about 150 bucks total in the whole system.
I wind up listening to HD radio more than anything else but in the mountains where FM signals get rough, I have all the other options.
No glove boxes were harmed in this project.
Craig
Re: Hidden Radio Setups? [Re: denfireguy] #1564048
01/17/14 01:11 PM
01/17/14 01:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I put one under the seat & put a piece of mirror on the heater vent to use the remote with
Re: Hidden Radio Setups? [Re: BulletBob] #1564049
01/17/14 01:16 PM
01/17/14 01:16 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
Had my original 8 track modified by Barrys 8 Track repair. They soldered in a remote IPOD jack and RCA plugs for my Amp, so basically my ipod is going to be hidden in the console. I tested it in the car and it sounds great and looks 100% stock. Even plays the 8 tracks still.
Here is a pic of the back of the dash before install, you can see the wires out the back.
Re: Hidden Radio Setups? [Re: RoadRunner73] #1564050
01/20/14 05:23 PM
01/20/14 05:23 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
How concerned are you with listening to the radio? If you just want to play music from you phone and not have a radio you could get a small amp and use an 3.5 mm to rca patch cord to plug it directly to the phone. Use the amp to power you speakers and the phone for music. You could even put a volume control between the phone and the amp if you don't want to use your phones volume control.
If you want to be real slick, get an amp with a remote volume control and hook it up to a Bluetooth receiver and stream you music wireless. I've thought about doing this and removing, gutting, the radio's volume knob and replacing it with one to control an amp.
1958 Plymouth Suburban
Re: Hidden Radio Setups? [Re: RoadRunner73] #1564051
01/20/14 07:19 PM
01/20/14 07:19 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I have my radio in the glove box and it is a pain to listen to unless you only like one volume and one radio station. Plus, my glovebox is currently stuck so no music for me.
Re: Hidden Radio Setups? [Re: MuuMuu101] #1564052
01/20/14 09:01 PM
01/20/14 09:01 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Cassette player radio in glove box with the tape adapter for ipod in it. I ran the cord behind the dash and the plug that goes to the ipod sits in the ashtray.
Re: Hidden Radio Setups? [Re: MI_Custumz] #1564053
01/20/14 10:59 PM
01/20/14 10:59 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I had the guts of my original radio replaced with modern electronics to include an MP3 jack. Looks stock and provides great music.
Re: Hidden Radio Setups? [Re: moparcanuk] #1564054
01/21/14 03:43 PM
01/21/14 03:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I want to do this to my 70' B Body 8-Track radio. Who did you send yours to?
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hidden Radio Setups? [Re: RoadRunner73] #1564055
01/21/14 04:12 PM
01/21/14 04:12 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I'd recommend a sensibly priced Bluetooth capable receiver with a remote.
I singled out Pioneer in this link because their remotes work from about any angle
(compared to Alpine and others that require you to aim straight at the unit), opening up more placement possibilities.
A side benefit to the remote is that your eyes stay on the road.
Here's a good resource. http://www.crutchfield.com/g_300/All-Car...Brand%7cPioneer
Re: Hidden Radio Setups? [Re: 70b5bird] #1564056
01/21/14 04:29 PM
01/21/14 04:29 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
http://www.casmfg.com/Mopar.htm
Got one in my 72 RR. Works great.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Hidden Radio Setups? [Re: 6PKRTSE] #1564057
01/21/14 09:09 PM
01/21/14 09:09 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
There is a guy in beverly hills michigan ( off woodward) that does these. did a 68 barracuda am radio. converted it to am /fm and added a jack for mp3 player. was about $500. and could not tell,a friend had this done, it was about 4 years ago. I'll see if he still has the number.
Re: Hidden Radio Setups? [Re: moretoys] #1564058
01/21/14 09:43 PM
01/21/14 09:43 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I added an mp3 jack to my factory am radio, cost me $3 in parts from radioshack.
i found a site about converting corvair radios, same idea and very simple
link
Re: Hidden Radio Setups? [Re: Diplomat440] #1564059
01/21/14 10:27 PM
01/21/14 10:27 PM
Alabama
BigMoneyLewis Offline
Alabama
The modern FM conversion is a pretty popular way to go . We did about a hundred Mopar FM conversions last year . I just finished the '69 Dart radio pictured below this afternoon . You would never know by looking at it that it has a modern FM stereo board with 4 speaker outputs, 180 watts total power and aux jacks .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Hidden Radio Setups? [Re: moretoys] #1564060
01/22/14 04:03 PM
01/22/14 04:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Let me know if you come up with his info or #. I am in that area off of Woodward all of the time.
