Suspension - shocks effect on over/understeer #156398
11/25/08 12:05 PM
11/25/08 12:05 PM
Anonymous OP
Anonymous OP
Wondering if one of the suspension gurus on here can enlighten me a bit on shock absorbers' contribution to over & understeer. For example if they're worn, they contribute one way or the other - or if we go with stiffer ones, what happens. Thanks in advance! ~Scott
Re: Suspension - shocks effect on over/understeer #156399
11/25/08 07:58 PM
11/25/08 07:58 PM
Klamath Falls, Oregon
Dartslantsix Offline
The shock's effect on under/over steer is just in the transient phase. Meaning when you start turning, before the car takes a set. The shock determines how quick or not quick the car takes a set.
An example, if the car is set up with the springs and sway bars to handle neutral. A shock that is too stiff in the front (compression) will intially cause understeer. But once the car it "set" it will handle neutral.
That's as basic as I can get it...the science to this goes on forever!
Re: Suspension - shocks effect on over/understeer [Re: Dartslantsix] #156400
11/25/08 09:12 PM
11/25/08 09:12 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Shocks and springs are a carefully matched pair under the right conditions. The shock is designed to control the motion of the suspension. Damping is a function of spring rate among many other things.
