Roller cam lobe profiles need a lot of valve spring pressurs to keep the rollers on the lobes at RPM, the higher the RPM the more spring pressures needed
As already stated if your running a hydraulic roller use a set of sprins that will have 150 t0 200 lbs on teh seta sand at least 400 to 425 lbs over the nose, not any more than the cam company recommends
I use springs that have at least 230 to 275 lbs on the seats and 600 Lbs. + over the nose, sometimes as high as 850 lbs over the nose, on the bigger solid roller lifter cams. the higher the shift RPM the more pressures needed to keep the roller from flying off the nose at RPM
The old adgae of a little to much spring pressures on roller cams is just right
