Re: gear vendors overdrive - someone with a little knwldge
[Re: Tim L]
#1563860
01/16/14 07:04 AM
01/16/14 07:04 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I think you can get away with the foot switch by putting in a switch at your discretion but the GVO works with a speed sensor which is controlled by the box and engages overdrive. The speed sensor has a speedo cable going from one end of the transmission, to an intermediary transfer with 2 14ga wires on it. These two cables go up to the control box, the control box has power, ground, speed sensor (2 wires) and plus your foot switch....You really need that speed sensor and the control box because the control box also has a toggle switch that allows you to choose Manual Shift or Auto Shift (for the OD)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: zhandfull]
#1563863
01/16/14 04:01 PM
01/16/14 04:01 PM
Posts: 861 lancaster,california
johnnycuda
I have a GV in my 'Cuda,I used to have it a D200 truck I used to have, when I installed it in the 'Cuda I did not use the boxes or foot swithch, only a toggle to activate the overdrive. I did this as my 727 does not have a speedo gear in it, and my trans has a reverse manual valve body so the kickdown isn't there either. I used to sell them at my previous job and I asked GV about what I planned to do and was told as long as I didn't make a habit of leaving the toggle turned on,( turn it off when coming to a stop) it wouldn't be a problem. If I was to leave it on when pulling from stops etc., I could burn up the overdrive unit. The reason being I wasn't using the control box and speedo cable adapter. My car has 4.56's with a 295/55-15 tire, and the rpm is 3000@70mph.You can purchase those items separately, they will need to know what gear ratio and tire diameter you have to provide you with the correct speedo gear.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Dabee]
#1563865
01/17/14 08:46 AM
01/17/14 08:46 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Plumb a pressure switch in the governor circuit, just like a A-500 conversion.
"I think its got a hemi"
[Re: Tim L]
#1563866
01/17/14 05:17 PM
01/17/14 05:17 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The GV unit has an internal hydraulic pump that pressurizes a cone clutch to engage the OD. The solenoid valve controls the fluid flow to the clutch so, when the trans output shaft isn't turning, there is no pump output and (I'm spitballing here) the clutch would disengage the OD...IOW, if the solenoid valve is energized and the car is at a standstill there would be no OD but the OD would engage as soon as the pump output is sufficient.
[Re: John_Kunkel]
#1563867
01/17/14 08:28 PM
01/17/14 08:28 PM
Posts: 3,455 Dandridge TN
Dabee
Dandridge TN
John you are correct. But, GV recommends not engaging the unit below 45 mph. This is to keep the cone from slipping until sufficient pressure to engage the cone clutch is generated. The control unit does that when wired into the system. Since he doesn't have the control box, he needs to manually engage and disengage the GV when passing through 45mph to keep the cone from slipping and causing premature wear.
[Re: Dabee]
#1563868
01/17/14 11:23 PM
01/17/14 11:23 PM
Posts: 12,221 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I wonder why GV did not use pressure rather than speed to switch the unit into and out of OD? Wouldn't different rear gear ratios result in different speeds at which the minimum pressure would be achieved?
Master, again and still
[Re: Dabee]
#1563871
01/18/14 10:34 AM
01/18/14 10:34 AM
Posts: 319 Northern Va
Mopar73340
Northern Va
Not trying to start a pissing contest here but the above is true when the control box is in AUTO mode. When the control box is in MANUAL mode and the switch to engage the unit is turned on the OD will engage at any speed above 20MPH +- If left in the on mode as you come to a stop the control box will disengage the OD at 20MPH +- I would think that if there was a possibility of damaging the unit by turning it on below 45MPH that the control box would not allow this to happen in manual mode.
[Re: Mopar73340]
#1563872
01/18/14 02:44 PM
01/18/14 02:44 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
So, the key to the success of the unit is the speed of the tranny's output shaft so that there is enough pump speed to generate enough pressure to keep the cone engaged? Right?
Vehicle speed is not important, just tranny output shaft speed. So the pressure switch is a better choice. Right?
[Re: DaveRS23]
#1563873
01/19/14 12:26 AM
01/19/14 12:26 AM
Dabee
Dandridge TN
You can use a pressure switch to control it but you will have no control over the GV. Do you really want it to shift into overdrive while you are still in first gear? With a manual switch you have control. I have a reverse manual valve body in my trans. I run through the gears then shift it into overdrive. It's like having a four speed. Around town I leave the the overdrive disengaged.
[Re: Dabee]
#1563874
01/19/14 01:10 AM
01/19/14 01:10 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
So, pressure switch plus a manual switch. Got it. Thanks.
