37 Pickup Headlight #1563773
01/16/14 12:10 AM
01/16/14 12:10 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
This is Boosted's Truck, it has this chrome trim
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Pickup Headlight [Re: AZ_A12_BEE] #1563774
01/16/14 12:12 AM
01/16/14 12:12 AM
Dreaming of the 808
Dreaming of the 808
This is my 37, is mine stock? If so it seems you can't change the headlight without tearing up the paint. Where did that chrome trim come from?
Re: 37 Pickup Headlight [Re: AZ_A12_BEE] #1563775
01/16/14 12:28 PM
01/16/14 12:28 PM
E
earlymopar Offline
earlymopar  Offline
E
Yes, yours is stock. There were a few companies that also made sealed beam conversion kits for the 35-38 commercial models that came with a new and larger ring.
- EM
Re: 37 Pickup Headlight [Re: earlymopar] #1563776
01/16/14 12:33 PM
01/16/14 12:33 PM
E
earlymopar Offline
earlymopar  Offline
E
Looking closer at your picture it appears that yours has been modified and is not a factory stock non-sealed beam (reflector and replacable bulb). Your buckets also look like they are from a sedan or coupe and are not commercial (panel, pickup). Its difficult to tell from the picture.
- EM
Re: 37 Pickup Headlight [Re: AZ_A12_BEE] #1563777
01/16/14 08:07 PM
01/16/14 08:07 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
To me, this light actually looks like the lights used on the old snow plows! Might be the picture, but it really doesn't look like the contour matches up at the attaching point like the pictures from the other truck does. It also looks a little smaller/shorter. Gene
Re: 37 Pickup Headlight [Re: AZ_A12_BEE] #1563778
01/16/14 08:49 PM
01/16/14 08:49 PM
Jacksonville Florida
elitecustombody Offline
Yours been modified. Stock only has thin stainless trim ring. You just push and twist to pop the lens and guts out.It's spring loaded.
The big chrome trim in first pic is definitely not original.
