Removing a vinyl top what to use #156373
11/25/08 08:51 AM
11/25/08 08:51 AM
Michgian
moparfun340 Offline OP
Michgian
I am going to remove my vinyl top on my challenger. Will it come off by hand and what do you think is the best way to clean the glue off. Also if I just paint to the vinyl top trim on by the back do you think it will look good. Please give me your thoughts or things that you have done. Plus will I find a lot of body work that I can not see now?
Re: Removing a vinyl top what to use [Re: moparfun340] #156374
11/25/08 09:16 AM
11/25/08 09:16 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We've had them come off in one piece and we've had them come off in several little pieces. Mostly several little pieces.
A razor blade or scraper is useful to pry the little bits off. To get the glue off I use a DA air sander. Aircraft stripper will work too if you don't have tools or a compressor. I wouldn't use this if you are trying to save the paint on the rest of the car, though.
We've never had a problem with a severely rusted top that was under vinyl but I know of several guys that have. At worst we've found surface rust that we ground off.
Re: Removing a vinyl top what to use [Re: dustergirl340] #156375
11/25/08 10:05 AM
11/25/08 10:05 AM
Inver Grove Heights MN
74RR Offline
74RR  Offline
Would a heat gun work to loosen up the adhesive?
Re: Removing a vinyl top what to use [Re: 74RR] #156376
11/25/08 11:20 AM
11/25/08 11:20 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I just put some thinner in my paint gun (without air) and squirt it on the roof in small workable areas. Let it sit for a few seconds, and scrape it off. Nice because you can control the thinner, and area you are working on.
Re: Removing a vinyl top what to use [Re: moparfun340] #156377
11/25/08 06:32 PM
11/25/08 06:32 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Are there any bubbles under the vinyl? If so, you've got rust.
When I pulled the vinyl off my Dart the sunroof panel, it had a few bubbles.
But, once I got the vinyl off I ended up having to replace the entire roof. And mine is a factory sunroof car.
Fortunately, Mark Nixon came through with an entire roof with a factory sunroof that I installed myself.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
