Are there any bubbles under the vinyl? If so, you've got rust.
When I pulled the vinyl off my Dart the sunroof panel, it had a few bubbles.
But, once I got the vinyl off I ended up having to replace the entire roof. And mine is a factory sunroof car.
Fortunately, Mark Nixon came through with an entire roof with a factory sunroof that I installed myself.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
