Re: 2008 Dodge cummins waterpump
[Re: EV2DEMON]
#1563688
01/16/14 02:45 PM
01/16/14 02:45 PM
Guitar Jones
Changing the pump is easy but the pumps are not cheap, like $300 just for the pump.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1563689
01/17/14 11:15 AM
01/17/14 11:15 AM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
I dont know where you are finding the $300.00 water pumps but if that is truely what you are paying I will sell them to you for $200.00 so you save a hundred.. NAPA, Oreillys, and Autozone all have them for $90.00.
[Re: rumblebee4232]
#1563690
01/17/14 12:32 PM
01/17/14 12:32 PM
Guitar Jones
Dodge dealers list price for a new one. I could be wrong but I thought they were about that last time I checked.
[Re: camastomcat]
#1563691
01/18/14 05:02 PM
01/18/14 05:02 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Mine went out at 88k. Very easy to swap it out. Now the drive belt is another story... Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: moretoys]
#1563694
01/23/14 01:13 AM
01/23/14 01:13 AM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
If you have a truck shop / cummins dealer near you, go there. It's the same pump as the dealer except much cheaper. easy to do, take longer to bled the system,get it up to temperature for the thermostat to open. Takes alot of coolant.
agreed.... I value my Cummins engine much more than to put an aftermarket rebuilt junk water pump on my motor so its either Mopar/Cummins (both the same) or nothing. ESPECIALLY thermostats..... I only use Cummins brand thermostats.
I work for a dealership and cannot tell you how many customers have tried to take the cheap way out and buy an aftermarket pump & or thermostat only to come to us and buy an OEM once their aftermarket junk has left them with a tow bill......
[Re: E-Ticket]
#1563695
01/23/14 04:22 PM
01/23/14 04:22 PM
Posts: 6,608 Indiana
EV2DEMON
The Camaro Kid
The Camaro Kid
Indiana
The original water pump on my truck failed after 4 years and 48000 miles. How can an aftermarket part be any worse than that?
[Re: EV2DEMON]
#1563697
01/24/14 09:06 PM
01/24/14 09:06 PM
E-Ticket
Louisville, KY
While there have been OEM pump failures....most all the ones I have seen or heard about typically started leaking and very few had the bearing expire. I experienced a leaking water pump on my 03 truck at approximately 60,000 miles but didn't know it was leaking until I turned the engine off. It barely leaked while running so that allowed me to keep going until I got home to change it. The bearing was fine....it was just the internal seal.
Cummins parts, as with most OEM parts that are made for the auto manufacturer's....have to hold a much tighter tolerance in the manufacturing process of the parts than do the "stock" aftermarket parts manufacturer's. I was in the manufacturing industry for a better part of 25 years and if you were to see what I have seen over the years...you would most likely never even consider a "stock" aftermarket part that the engine rely's on to function properly......
[Re: E-Ticket]
#1563698
01/24/14 11:13 PM
01/24/14 11:13 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
....Listen to what this man is saying.....
